> i think a sensor, car idles up and down and will die if i hit the gas
post Mar 12, 2012 - 10:14 PM
my96celica
Joined Jul 15, '07
From High ridge MO
I bought another celica. 4th one now btw and the person did a motor swap on it. its a 91 gts with a 5sfe motor in it and i have a plug on the harnest not pluged in and i think its the cold start injector that was on the gts motor. car will start but idle from 1000 upto 1600 and keep doing it. a while later the car will idle high so i hit the gas and the car will start to die. ive been told a tps or a map or IAC Which is 300 bucks i dont have. plz help and dont say junk the car.. it runs great b4 this happened
post Mar 12, 2012 - 10:40 PM
Box
Joined Feb 23, '12
From Warrior, AL
Might be able to find tests online for said components. Easy way to test is to unplug things as the car is running and see if it makes a difference to how it's running. Maybe something just needs adjusting. I had a 3000GT where the IAC had went bad, would idle funny and as soon as you put it into gear it'd choke out and die unless you kept your foot on the gas.
2001 Miata LS 5-speed
post Mar 12, 2012 - 11:40 PM
my96celica
Joined Jul 15, '07
From High ridge MO
no i dont step on the gas at all. i start it and it will idle up and down till it stays at a high idle then i push the gas and the car loses power. the more gas i give it the more th rpms drop till i kill it.
post Mar 13, 2012 - 2:12 AM
Box
Joined Feb 23, '12
From Warrior, AL
Hmm, odd. Just start by checking all the components out. If the IAC, MAP, and TPS check out you know it's something else.
Something on IAC: http://www.toyotanation.com/forum/103-3rd-...s-pictures.html
Something on MAP: http://www.toyotanation.com/forum/103-3rd-...r-behavior.html
Something on TPS: http://www.toyotanation.com/forum/103-3rd-...-tps-5s-fe.html
Can get used parts for cheap. That and there's always Rock Auto
This post has been edited by Box: Mar 13, 2012 - 2:13 AM
post Mar 13, 2012 - 9:24 AM
richee3
Joined Jun 29, '08
From Denver
Have you checked for codes yet?
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 13, 2012 - 11:48 AM
my96celica
Joined Jul 15, '07
From High ridge MO
no cel comes on. im going to replace the tps and fuel filter now. if that is not it im out of ideas.
post Mar 13, 2012 - 1:35 PM
my96celica
Joined Jul 15, '07
From High ridge MO
my motor dont have a plug on the intake manifold. that means its a newer 5sfe motor right? should i get parts for the 94 to 97 motor?
post Mar 13, 2012 - 2:55 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Check your timing....specifically around the distributor...sounds like it is going bad. My former 7a did the same exact thing...I checked every damn sensor, changed this and that..even the distributor cap, ended up the distributor itself was causing such issue.
You have a 5sfe 2.2 engine. Year depends on obd1 and 2, not engine model itself.
This post has been edited by rave2n: Mar 13, 2012 - 2:58 PM
post Mar 13, 2012 - 3:31 PM
my96celica
Joined Jul 15, '07
From High ridge MO
so take the cap off or turn it or what? replace the whole thing? they cost alot to replace if its not that
is there a way to check the tps or distributor?
post Mar 13, 2012 - 3:50 PM
rave2n
Joined May 29, '09
QUOTE (my96celica @ Mar 13, 2012 - 4:31 PM) *
Got a haynes manual? Gives you step by step on both
And I'll bet money its not the TPS.
If its dying when you hit the gas, its most likely timing related.
This post has been edited by rave2n: Mar 13, 2012 - 3:51 PM
Lo-Fi Version Time is now: February 18th, 2025 - 7:51 PM
