I tore my 1MZ down this weekend |
Mar 12, 2012 - 10:30 PM |
This guide is for reference only. This is how I tore down the 1MZ-FE engine over the weekend. Here is the engine when I started. I mounted it on an engine stand and went to work.
Here are a few shots so I can remember vacuum lines. I removed the power steering pump here. there are 2 bolts holding it to the block I took the engine cover off to show the VSVs and the fuel rails. It looks like some critter built a nest on the valve cover. There is another one on the back side of the head. I really wanted to slap the guy at the junkyard for telling me this is a good clean block. I unplugged the spark plug wires from the coils to the rear plugs These are the 2 spots there those wires are secured down. I just unclipped the clip and removed the 10mm bolt. Here you see the wires going back to the rear plugs. Using a needle nose pliers you squeeze the tabs together and the mount pops off. I also removed the 2 intake manifold support bars. Here I'm just making sure that I know where all the vacuum lines are going to the VSVs. Here I unplugged the 3 coils from the wiring harness and moved it out of the way. These next 2 pics are the wire going down to the oil pressure sensor and crank position sensor. Here I'm removing the passenger side engine mount. Here it looks like I just remove a harness ground from the intake manifold, you can also see on the left where I removed the EGR. To get to the back injector plugs I had to remove the intake manifold. With those last injectors unplugged I was able to remove the wiring harness. Next I started on the AC compressor. I removed the bolts holding it to the block and this bracket Here I removed the timing belt covers. Its held on by 10mm bolts. My heavy duty impact gun was able to break the crank pulley loose. Getting it off was another story. I had to build a makeshift gear puller to get it off. This is looking down on top of the block, Here I'm removing the lower runners of the intake manifold. Here you can see that weird bug nest. This is the lower intake manifold removed. Here is the right side of the engine, this is where the thermostat is hiding. The brass sensor is the water temp sensor Here I removed the hard water line and the thermostat. Here I removed the water filler hard pipe and the soft water hose. You can see the 2 knock sensors here. Finally got the crank pulley off. Stick a small allen wrench in the timing belt tensioner and remove the tensioner. Removed the timing belt. To get the black timing belt cover off you have to remove the cam gears. They are both the same gear except on the rear bank its on backwards. You can see the lip on the gear is swapped. To get the cam gears off, use a wrench on these “gears” on the cams to prevent them from rotating. Use a large breaker bar on the nut on the actual cam gear. The cam gear bolt is a 17mm. Here the cover is off, its also easier to get off the idler pulley mount off now. I removed the cams and kept the caps in order. I also marked the shims and buckets for their location. I used the naming convention of Front Intake 1 or Front Exhaust 1 Here is a close up of the Rear bank. What I'm calling the front bank actually has an L in the casing. I removed the front head. The head bolts are 12mm 12pt bolts and there is a single allen head bolt too. Both heads removed The cylinder walls, it was so dirty in this engine. I'm so glad I'm doing this rebuild. I remove the AC mounting bracket on the block and the front engine mount. Remove the timing belt tensioner pulley. You can see the water pump on here too. Remove this exhaust thing. Water flows behind it, so I'm assuming its used to cool down the exhaust. Here the water pump is removed. It was actually looking good, but I'm still going to replace it. Looking down, next to remove is this water line block cover. I don’t know what to call it. Once I got that thing off I flipped the engine over and removed the #2 oil pan. Remove the oil pickup. The # 1 oil pan is held on by 12mm bolts and a few 10mm bolts at the oil pump and rear main seal assembly. Rear main seal assembly removed. Oil pump removal. Here is the first rod and piston removed. The skirt on the sides of the piston looks good. I can tell you now that the 1MZ-FE rods look about the middle in strength between a 1ZZ-FE and 2ZZ-GE. They are smaller than a 5S-FE and 3S-GTE. Once I go through all my boxes, ill make a good comparison picture. There is a small dimple on the top of the piston to indicate forward. The rod also has a similar mark, here you can see it. It’s the tab right in the middle and bottom of this rod. The other side is just round. All the pistons and rods. Ill clean them up when I'm ready to re-assemble. Next is get the mains out. These are 6 bolt mains. There are 2 bolts on each side and there is also a single bolt on the sides of the block. It took me a minute to figure out what those were for. The mains are numbered so you cant mix them up. Looking at this main, the #2 that’s raised in an arrow pointing up is the actual number of the main. Not the number 2 stamped in the middle. Crankshaft out. Here you can see the iron inserts in the block. I think you can get away with a .020 overbore with these inserts. After that you will need something like a Darton sleeve. There is plenty of room between the cylinders for that. Here is everything on my tables. Lots of parts in there. I didn't take pics of the head dis-assembly but when i built everything back, i will take good pictures. I promise -------------------- 2001 Celica GT-S Turbo
Mar 12, 2012 - 10:42 PM |
Enthusiast Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
Holy dirty ass engine batman... Lookin good jeff. Gonna go all out and machine everything? ARP? Stroker whattttt??
This post has been edited by SupraKid: Mar 12, 2012 - 10:43 PM |
Mar 12, 2012 - 10:54 PM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Fun - I'm along for the ride.
Mar 12, 2012 - 11:28 PM |
Enthusiast Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) |
Looking dirty yet awesome! Good luck with the rebuild and cleaning!
-------------------- (\__/)
Mar 13, 2012 - 9:16 AM |
no big build, ill just hone the cylinders, new rings and bearings. new gaskets. valve job. just making it a fresh new engine.
Mar 13, 2012 - 6:02 PM |
At least ARPs and a lightweight flywheel?
This post has been edited by SupraKid: Mar 13, 2012 - 6:03 PM |
Mar 13, 2012 - 6:30 PM |
At least ARPs and a lightweight flywheel? At least ARPs with a lightweight flywheel and a 50-shot? (somebody keep adding to this ) -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Mar 13, 2012 - 6:50 PM |
yes Fidanza flywheel, Southbend clutch. Nitrous? hhmm hadn't thought about that, sounds like fun. but i have planned on supercharging it once i get it passed the SMOG NAZIs
Mar 13, 2012 - 9:13 PM |
Needs moar cam lobe and compression with a good stand-alone ECU. Oh wait...this isn't a 2ZZ.
Mar 13, 2012 - 9:37 PM |
Gonna get a TRD or go custom?
Mar 13, 2012 - 11:58 PM |
you know me, i do everything custom!
Mar 14, 2012 - 3:10 AM |
yes Fidanza flywheel, Southbend clutch. Nitrous? hhmm hadn't thought about that, sounds like fun. but i have planned on supercharging it once i get it passed the SMOG NAZIs Would be nice to see this get a shot of nitrous... Why no turbo? -------------------- 1993 Celica GT Coupe - sold
Mar 14, 2012 - 11:13 AM |
space for the most part. Ill know more once i get it in there. i should be picking up the block and heads from the machine shop today. i just have everything hot tanked. should look brand new once i get it back
Mar 14, 2012 - 11:15 AM |
space for the most part. Ill know more once i get it in there. i should be picking up the block and heads from the machine shop today. i just have everything hot tanked. should look brand new once i get it back Oooh - pics of that please -------------------- |
Mar 14, 2012 - 11:38 AM |
Take my word for it
Its super cramped in the engine bay Your best bet will be to delete the a/c pump an mount the charger there or do one of those turbo setups that put the turbo at the back of the car inline with tbe exhaust -------------------- 95 gt coupe, v6 swap weekend toy
Mar 14, 2012 - 11:45 AM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
nice! I will follow this for a while.
-------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Mar 14, 2012 - 3:11 PM |
Take my word for it Its super cramped in the engine bay Your best bet will be to delete the a/c pump an mount the charger there or do one of those turbo setups that put the turbo at the back of the car inline with tbe exhaust no way will i delete AC here in the desert. it gets over 115 here in the summer -------------------- 2001 Celica GT-S Turbo
Mar 14, 2012 - 6:03 PM |
Well id go with the exhaust mounted turbos then cuz the only other simi free space is over top the trans.
You might be able to use the trd super charger if it will cleat the hood -------------------- 95 gt coupe, v6 swap weekend toy
Mar 14, 2012 - 6:55 PM |
MR2 guys put the turbos over the top of the transmission. If there is space to twin-charge a MR2 there is room in a Celica for two turbos and a supercharger. Piping would be tight, but it's possible.
Mar 15, 2012 - 1:28 AM |
MR2 guys put the turbos over the top of the transmission. If there is space to twin-charge a MR2 there is room in a Celica for two turbos and a supercharger. Piping would be tight, but it's possible. What would that be exactly? Twin-super-turbocharged? -------------------- 1993 Celica GT Coupe - sold
Lo-Fi Version | Time is now: November 21st, 2024 - 7:07 PM |
