I tore my 1MZ down this weekend |
Dec 22, 2013 - 4:50 PM |
nothing at all, It is looking for the newer style EVAP system that the 99 celica has. the 97 ECU looks for a similar EVAP system to what my 97 celica has. This will make it easier to SMOG legalize the swap in CA
Sep 27, 2015 - 7:00 PM |
Enthusiast Joined Jun 21, '14 From Ottawa, Ontario, Canada Currently Offline Reputation: 0 (0%) |
Will the 3mz work with the s54 tranny? The 3MZ is about 30hp more than the 1mz,if I'm not mistaken?
This post has been edited by doory100: Sep 28, 2015 - 3:48 PM -------------------- |
Sep 27, 2015 - 9:33 PM |
yes im using an S54 now
Sep 28, 2015 - 3:55 PM |
From what I understand, you have a full 3MZ engine now, with a 97 ecu and wire harness from a 97 also, and a s54 transmission. As for the transmission it's a 3MZ flywheel with the 5sfe pressure plate and clutch disk. What else is needed to complete this awesome setup?
Sep 28, 2015 - 4:54 PM |
yes except im using a 1MZ/3MZ/2GR Fidanza flywheel with a 3S-GTE clutch however the disk has a center hub for an S54. Southbend makes this clutch and is ready to ship
Sep 28, 2015 - 6:37 PM |
yes except im using a 1MZ/3MZ/2GR Fidanza flywheel with a 3S-GTE clutch however the disk has a center hub for an S54. Southbend makes this clutch and is ready to ship I just put a stage 3 phenox friction clutch in my 5s last year and Its got about 700 miles on it so I kind of wanted to keep it. How much was that flywheel? I heard lighter flywheels make a big difference. This post has been edited by doory100: Sep 28, 2015 - 6:40 PM -------------------- |
Sep 28, 2015 - 10:11 PM |
you put a stage 3 clutch in a stock car??? WHY?
you will not be able to use that clutch. yes lightweight flywheels are nice. you can get it here http://www.monkeywrenchracing.com/product_...kgpmkm8hl9tl7d7 -------------------- 2001 Celica GT-S Turbo
Sep 29, 2015 - 7:05 AM |
That would be nice. I might get one if the Canadian dollar goes back up. But it's not like I'm installing it tomorrow. So I have to have the southbend modified 3sgte clutch and 3sgte pressure plate or is there another option? Sorry for all the questions.
I put the stage 3 because it was a good price and I wanted to make sure if I did turbo it would be able to handle it. -------------------- |
Sep 30, 2015 - 7:55 AM |
i believe ACT also makes this clutch but their quality has gone to crap! Never do business with them again.
the clutch is basically a 3S-GTE clutch with the disk having a hub o mate with your S54 trans. -------------------- 2001 Celica GT-S Turbo
Sep 30, 2015 - 5:37 PM |
I found a 1999 solara with 248000 miles on it. It runs good. The guy wants $200 for the entire car. Or $100 for the engine? Do you think it's a smart move if I rebuild the motor and drop it in my celi? Or should I find one with less miles?
This post has been edited by doory100: Sep 30, 2015 - 5:40 PM -------------------- |
Sep 30, 2015 - 6:50 PM |
It's probably OK to rebuild, worst case you get new liners and bearings all over and have the heads rebuilt, you'd have a brand new engine then for less than a brand new engine.
Oct 1, 2015 - 7:49 AM |
It's probably OK to rebuild, worst case you get new liners and bearings all over and have the heads rebuilt, you'd have a brand new engine then for less than a brand new engine. yes for that price it wouldnt hurt to just replace the bearings, piston rings, hone the cylinders, replace the valve stem seals and the valve cover seals. -------------------- 2001 Celica GT-S Turbo
Oct 1, 2015 - 4:34 PM |
I would also do the head gasket, timing belt and water pump. There. Is a rebuild kit on rock auto fot the 1mz. Its $460. Do you think I need that many parts?
Oct 1, 2015 - 7:56 PM |
do you happen to have the part number for the southbend 3sgte clutch that fits a s54 transmission?
Oct 2, 2015 - 9:20 AM |
no its not on their website, you have to call them and talk to Andy or John in the import dept. tell them I sent you
Lo-Fi Version | Time is now: November 22nd, 2024 - 6:33 AM |
