> Car running bad
post Mar 13, 2012 - 2:30 PM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
Need help ASAP plz, just started my car and it idles rly low and sounds as if it's about to shut off, as if it's being choked. Car has no power and eventually would shut off on its own. Anybody got any ideas to what this might be
I only want to be faster than the guy next to me.
post Mar 13, 2012 - 2:53 PM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (99celiGT @ Mar 13, 2012 - 3:30 PM) *
Well we don't have much to go on, but it could be 1 of many things.
I'd start with fuel pressure, go rent a fuel pressure testing kit from autozone for 25 smackers, and confirm your line is within PSI specs.
Being you have a 99, is it throwing any code? and do you how to check for stored codes?
post Mar 13, 2012 - 3:11 PM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
How can I Check for stored codes, I'll check for fuel pressure once it gets towed home
post Mar 13, 2012 - 3:44 PM
celicomx
Joined May 10, '06
From El Paso, Texas
when was the last time you change spark plugs, wires, distributor cap and rotor? also the fuel filter??
post Mar 13, 2012 - 3:56 PM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
QUOTE (celicomx @ Mar 13, 2012 - 4:44 PM) *
All of those I have recently changed except the fuel filter, I'm starting to believe it leaning towards a fuel problem because now the car doesn't wanna turn over
post Mar 13, 2012 - 10:29 PM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
it should turn over regardless of fuel am I not correct? It just won't fire
post Mar 14, 2012 - 6:48 AM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
QUOTE (PolliS_5S-FE @ Mar 13, 2012 - 11:29 PM) *
It does crank but doesn't turn on, I took the bolt from the top of the fuel filter then put the key in the on switch and no fuel was being shot out of the filter
post Mar 14, 2012 - 9:59 AM
QUOTE (99celiGT @ Mar 13, 2012 - 4:11 PM) *
Use the OBDII port on the driver's side of the engine bay, should be a little black box right behind the wheel well, directly in front of the brake booster. Any auto shop can do it for you.
Lo-Fi Version Time is now: November 26th, 2024 - 7:44 PM
