> help car overheats
post Mar 16, 2012 - 1:31 PM
st202import
Joined Feb 1, '12
From england
hi guys hoping you can help me when stopped with the engine running or in traffic the car overheats then sprays coolent all over my engine bay frown.gif not good when u turn up to a car cruise n my car takes a wee infront of everyone kindasad.gif,
is it the sensor or my thermosat or is just my fans are dead ?
post Mar 16, 2012 - 4:08 PM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
I think its more than the fans if its spraying coolant mate! hahaha, you'll need to be checking everywhere for cracks in the rad, check the hoses are strapped on proper, no splits and change the radiator cap. Idle the car with the bonnet open and have a look!!!! Just dont get burnt
post Mar 17, 2012 - 2:43 PM
st202import
Joined Feb 1, '12
From england
theres no cracks in the rad all hoses are on and fine and ive swapped rad caps , the coolent came out off the over-flow , only gets hot when its stationary kindasad.gif but the fans do not kick in at all kindasad.gif
post Mar 17, 2012 - 3:39 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
stationary and by city driving the engine gets realy hot (becouse of the less air flow)
pull out the connector from the fan swich (on the radiator next the outlet), so they must start to run
you can also check the fuse -> 30A CDS and RDI
greetz
KEEP COOL UNDER PRESSURE
post Mar 17, 2012 - 3:45 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
thats why you are overheating, the fans are not kicking on. check the wiring, the fans themselves, or the relays.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 18, 2012 - 8:31 PM
m2736185
Joined Jun 4, '10
From Jax Beach, FL
If you remove the fan switch connector and the fans dont turn on your problem has something to do with the fan. If it turns on then you should check the thermostat to make sure its opening or the sensor the switch is connected to.
post Mar 20, 2012 - 2:04 PM
st202import
Joined Feb 1, '12
From england
cheers guys i shall try this soon as smile.gif much thanks
Lo-Fi Version Time is now: November 23rd, 2024 - 3:47 AM
