WHAT SHIFT KNOB YOU ROCKING?, POST A PIC AND NAME OF YOUR SHIFT KNOB |
Mar 29, 2012 - 9:30 AM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Threw it on last night:
Mar 29, 2012 - 9:54 AM |
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Mar 29, 2012 - 12:54 PM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
Double like... I super dig this. How was it made? Is it dense wood or does it feel light? This post has been edited by HectortheRican: Mar 29, 2012 - 12:54 PM -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Mar 29, 2012 - 8:50 PM |
Enthusiast Joined Nov 6, '07 From seattle Currently Offline Reputation: 4 (100%) |
Double like... I super dig this. How was it made? Is it dense wood or does it feel light? Well I made it from a wooden ball from arts and crafts store. Then I just used some fine grit sandpaper made it smooth then stained it. After that I just drilled out a bigger hole in the ball, that was a bit smaller than the shifters diameter and screw it on. Forgot where the locking screw was from, but its similar to ones that come with other ball knobs to lock them in. As for weight it's light, but the feel is just right for my short shifter. This was the last knob I changed since I did this since I liked the look of it so much, and I have been using it for over two years now. http://www.sears.com/shc/s/p_10153_12605_S...u=SPM5671140203 < I used something similar to this from Joanne fabrics. Why I did this is due to me being bored shopping with my girlfriend, saw the knob and it kind of just seemed like a good idea. p.s. at the moment I'm still working on a bootless cover. Similar how some cars just have a cutout plate that shows the shifting path. I'll postt updates when ever I'm not studying. This post has been edited by bizzerk: Mar 29, 2012 - 9:05 PM -------------------- |
Mar 29, 2012 - 9:09 PM |
Well I made it from a wooden ball from arts and crafts store. Then I just used some fine grit sandpaper made it smooth then stained it. After that I just drilled out a bigger hole in the ball, that was a bit smaller than the shifters diameter and screw it on. Forgot where the locking screw was from, but its similar to ones that come with other ball knobs to lock them in. As for weight it's light, but the feel is just right for my short shifter. This was the last knob I changed since I did this since I liked the look of it so much, and I have been using it for over two years now. http://www.sears.com/shc/s/p_10153_12605_S...u=SPM5671140203 < I used something similar to this from Joanne fabrics. Why I did this is due to me being bored shopping with my girlfriend, saw the knob and it kind of just seemed like a good idea. p.s. at the moment I'm still working on a bootless cover. Similar how some cars just have a cutout plate that shows the shifting path. I'll postt updates when ever I'm not studying. .... I may be implementing this idea. That just looks fantastic. -------------------- taking too long to mod since '09
Mar 29, 2012 - 9:15 PM |
Well I made it from a wooden ball from arts and crafts store. Then I just used some fine grit sandpaper made it smooth then stained it. After that I just drilled out a bigger hole in the ball, that was a bit smaller than the shifters diameter and screw it on. Forgot where the locking screw was from, but its similar to ones that come with other ball knobs to lock them in. As for weight it's light, but the feel is just right for my short shifter. This was the last knob I changed since I did this since I liked the look of it so much, and I have been using it for over two years now. http://www.sears.com/shc/s/p_10153_12605_S...u=SPM5671140203 < I used something similar to this from Joanne fabrics. Why I did this is due to me being bored shopping with my girlfriend, saw the knob and it kind of just seemed like a good idea. p.s. at the moment I'm still working on a bootless cover. Similar how some cars just have a cutout plate that shows the shifting path. I'll postt updates when ever I'm not studying. .... I may be implementing this idea. That just looks fantastic. best part about it is you don't have to spend more than 6 dollars to make 4 of these -------------------- |
Mar 30, 2012 - 12:48 AM |
best part about it is you don't have to spend more than 6 dollars to make 4 of these My favorite part will be the stain! It'll look fantastic! -------------------- taking too long to mod since '09
Mar 30, 2012 - 7:29 AM |
p.s. at the moment I'm still working on a bootless cover. Similar how some cars just have a cutout plate that shows the shifting path. I'll postt updates when ever I'm not studying. I had done this last year but found out that the throw distance wasnt far enough to get a nice large gate like this The pattern would need to be higher up on the stick (which would look ridiculous because it would just be this big aluminum box sticking up from the shifter hole. I'm curious to see what your results are. The other solution I had thought about doing was to do an aluminum plate, then figure out the max throw positions and then CNC a hole to that max diameter, and find some kind of thin rubber grommet that would fill up that space and allow for the shifter to move freely still -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Mar 30, 2012 - 8:41 PM |
p.s. at the moment I'm still working on a bootless cover. Similar how some cars just have a cutout plate that shows the shifting path. I'll postt updates when ever I'm not studying. I had done this last year but found out that the throw distance wasnt far enough to get a nice large gate like this The pattern would need to be higher up on the stick (which would look ridiculous because it would just be this big aluminum box sticking up from the shifter hole. I'm curious to see what your results are. The other solution I had thought about doing was to do an aluminum plate, then figure out the max throw positions and then CNC a hole to that max diameter, and find some kind of thin rubber grommet that would fill up that space and allow for the shifter to move freely still Thanks for the great tip. When I finally have time and materials I can get started on testing out the pattern. My goal for this was to make a low profile cover to make it feel a bit more tidy in the interior. I did notice the range of the throws are quite short, so I might end up designing something less traditional and more of an arcade joystick esque design haha. http://www.slagcoin.com/joystick/attribute...s/joy_bunch.jpg I'll try different patterns out eventually. This post has been edited by bizzerk: Mar 30, 2012 - 8:48 PM -------------------- |
Mar 31, 2012 - 6:44 PM |
My favorite part will be the stain! Such was her diction as well. bizzerk, that looks effing cool. Nice job. -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Apr 1, 2012 - 9:10 PM |
Thanks for the great tip. When I finally have time and materials I can get started on testing out the pattern. My goal for this was to make a low profile cover to make it feel a bit more tidy in the interior. I did notice the range of the throws are quite short, so I might end up designing something less traditional and more of an arcade joystick esque design haha. http://www.slagcoin.com/joystick/attribute...s/joy_bunch.jpg I'll try different patterns out eventually. Yeah that kind of style is what I think is the only alternative to the stock boot sucks -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Apr 1, 2012 - 11:58 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
^ whered you get your custom shift boot? looks like the material is not like the thicker drier more texture gaiter types. mines not so good. I'm looking for a custom one that is thinner in material, shiny like the oem boots, and has less texture as much as possible. Advance Auto Parts. I fit it over the old ones wire frame and snapped it into place. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Apr 5, 2012 - 10:47 PM |
Enthusiast Joined Apr 2, '12 From texas hill country Currently Offline Reputation: 0 (0%) |
i liked everyone's shifters (well i wouldn't have the bubbly "dildo" shifter but i like that y'all have the balls to do it)
i got pulled over once and the trooper instantly noticed mine. after asking me about it and lecturing me about having my front license plate on my windshield he let me go. i guess just copy and paste the link http://www.facebook.com/media/set/?set=a.1...mp;l=bcd288394c |
Apr 5, 2012 - 10:51 PM |
Enthusiast Joined Aug 17, '09 From Millard, Omaha, Nebraska Currently Offline Reputation: 1 (100%) |
I bet the buttons shoot the rocket launchers and machine guns! That's cool man.
Apr 6, 2012 - 9:08 AM |
i liked everyone's shifters (well i wouldn't have the bubbly "dildo" shifter but i like that y'all have the balls to do it) i got pulled over once and the trooper instantly noticed mine. after asking me about it and lecturing me about having my front license plate on my windshield he let me go. i guess just copy and paste the link That's pretty effing cool actually. Microsoft stick, right? I still have mine sitting in a closet somewhere. Many Flight Simulator hours on that one... I bet the buttons shoot the rocket launchers and machine guns! That's cool man. LAL. That'd be a fun way of messing with a passenger. "Want to see my ejector seat?" This post has been edited by SwissFerdi: Apr 6, 2012 - 9:18 AM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Apr 6, 2012 - 11:56 AM |
Ejector seat. Lol. Makes me think of 2Fast 2Furious.
Apr 6, 2012 - 2:53 PM |
Enthusiast Joined Nov 29, '10 From Lake Havasu City, AZ Currently Offline Reputation: 31 (100%) |
-------------------- 6gcHeroes:808hectortimmybatmandiegotigamak |
Apr 6, 2012 - 9:41 PM |
Rockin' the stock one!
Apr 6, 2012 - 10:25 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
^ same here.
I really like the feel of it, just wish mine wasn't so worn out -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Apr 7, 2012 - 3:54 PM |
Enthusiast Joined Apr 20, '11 From College Station, Tx Currently Offline Reputation: 2 (100%) |
Momo weighted knob w/ 7th gen short throw. Kaos do you still have? if you do is it for sale? This post has been edited by matts94celica: Apr 7, 2012 - 3:55 PM -------------------- |
Lo-Fi Version | Time is now: December 4th, 2024 - 8:38 PM |
