> Phantom Grip LSD Conversion, 5SFE 87-92 5th Gen FWD GTS
post Dec 27, 2003 - 1:56 AM
Jabberwock
Joined Sep 22, '03
I was looking around and saw that the 5th gen GT celicas have a FF 5SFE engine and Phantom Grip makes a LSD for that application.
I was wondering if that LSD would fit onto the 6th Gen 5SFE tranny.
HEHE, if it does, my tires won't spin much with the 3SGTE swap.
post Dec 27, 2003 - 8:08 PM
Jabberwock
Joined Sep 22, '03
No one knows or no one wants to answer?
post Dec 27, 2003 - 8:50 PM
macavely
Joined Nov 4, '02
i dont think any one here as used it
post Dec 27, 2003 - 8:57 PM
a good idea is to swap in a mr2 turbo tranny with lsd. you can pick one up for around 600$ and you get the benefit of better gearing that the mr2 trubo provides.
post Dec 27, 2003 - 10:37 PM
Jabberwock
Joined Sep 22, '03
yeah but then I would have to get custom axels and the bellhousing might be a pain. its 600 but the price could sky rocket after the tranny is actually on the car.
I would rather go with the $200-300 LSD.
Also, I am not entirely sure if I will evantually go AWD....Just need a LSD solution for a while.
post Dec 27, 2003 - 11:19 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
It should fit... I believe all of the 5sfe trannies on the Celicas are the same.
post Dec 27, 2003 - 11:24 PM
Jabberwock
Joined Sep 22, '03
Thank You, thats what I really wanted to know Kwanza. Heh..I should have asked if the 5th gen 5SFE tranny is the same as the 6th gen's
post Dec 28, 2003 - 2:14 AM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
QUOTE (Jabberwock @ Dec 27, 2003 - 8:37 PM)
First off... you won't need custom axles. I've already stated in several posts what's needed: MR2 Turbo inner shafts and V6 Camry outter shafts.
As for the Phantom Grip... it's not a true LSD unit. GB's have been started in the past, but it fell through. If you want something reliable... get a true LSD unit... basically, you get what you pay for homie.
Lo-Fi Version Time is now: November 30th, 2024 - 7:38 AM
