> Raise 5SFE Idle
post Mar 21, 2012 - 7:10 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Ive searched around and couldnt find anything that helped.
Is there any way I would be able to raise my idle (just need 75rpm) with the SAFC2
or any other free method without having to dig into the ecu or grab an msd ignition
エキサイティングカーレーシングチーム!
post Mar 21, 2012 - 9:43 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Idk if ull want to do this but with my hondas i normally just let the engine warm up to where its at the normal rpms it sets at then i take 2 14mm wrenchs an adjust the throttle cable
94 st hatch my daily driver
n
post Mar 21, 2012 - 10:17 AM
199celica
Joined Jul 29, '11
From chino, Ca
I changed my idle with the little allen head screw that touches the throttle rotor. Just a thought
post Mar 21, 2012 - 10:30 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (kurt95gt @ Mar 21, 2012 - 10:43 AM) *
Never thought of that, that may be the best option. I only need 75-100rpm to get it down from a 9.5 on the richter scale to a 1
QUOTE (199celica @ Mar 21, 2012 - 11:17 AM) *
My 5S doesn't have that adjuster.
エキサイティングカーレーシングチーム!
post Mar 21, 2012 - 11:23 AM
199celica
Joined Jul 29, '11
From chino, Ca
oh O.O my bad i thought they all had them...
post Mar 21, 2012 - 12:55 PM
mkernz22
Joined May 10, '10
From MA
As I was doing my spark plugs today, I noticed some slack in my throttle cable (and the fact that the two nuts were loose). So I tightened it up until there was barely any slack and now she's idling at about 900-950, which is a lot better for me because the whole car use to rattle and crap around 700-800. She feels a lot more peppier from a stop and it feels better just getting going too.
The two nuts are on the throttle cable, they are just before where the protective covering stops. Those two mount the cable to the TB as well. I feel like you should know what I'm talking about, but if not, I can get a picture of two for you.
post Mar 21, 2012 - 1:03 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
yeah I know how to adjust it, it just never crossed my mind that I could do it that way.
Im excited to fix it. I hate how it sounds at idle right now
エキサイティングカーレーシングチーム!
post Mar 21, 2012 - 1:10 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
75-100 rpms wont take alot eather
n
post Mar 21, 2012 - 6:45 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Welp it didnt work. I adjusted it to its max position and there is still too much slack. I can't think of any other way than to tie a knot in the exposed wire area. Which I'd rather not do, any suggestions?
エキサイティングカーレーシングチーム!
post Mar 21, 2012 - 6:58 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Did you let it warm up first?
n
post Mar 21, 2012 - 7:59 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Yup. Still some slack with it fully pulled
エキサイティングカーレーシングチーム!
post Mar 21, 2012 - 8:17 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Would it be possible to shorten the Throttle Cable?
Like remove it and cut it? or not possible?
My Celica!
post Mar 21, 2012 - 8:20 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
I was thinking of it when I was checking it out but it was a definite no go. I think knotting it is a better method but it's an innacurate method. I could end up above my goal of 820-850
エキサイティングカーレーシングチーム!
post Mar 21, 2012 - 9:02 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
You could try and. Elongate the holes on the throttle cable. Mount
Or you could. Disconnect the cable and remove the rubber pease from the mount an replace it with 2 washers to hold the cable in place
That woukd give you some more room for adjustment
n
post Mar 21, 2012 - 10:21 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
ill look into spacing it with washers, i cant remember if i can get the one nut off (throttlebody side) of the cable or not. there is a small rubber grommet that is at the end of the threaded area, im not sure what it is covering, if anything at all.
エキサイティングカーレーシングチーム!
post Mar 21, 2012 - 10:42 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
If you pop that off you should be able to take the nut off
if not just get 2 washers an cut a notch in them to make them a c shape an use them the same way as the rubber pease worked
n
post Mar 22, 2012 - 2:44 AM
blackceclia0823
Joined Mar 22, '12
From rhode island
I ran into the same issue long time back when I put in my first tranny in my celica and i tie knot on the throttle cable on my celica had no issues. I would check to see if you alot of slack on the throttle cable before doing this though. I personal keep my rpms around 900 at idle anything else lower it start to vibrate.TPS might need to be adjusted make sure timeing is right.
post Mar 22, 2012 - 6:19 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Lol timing hasn't been right for over a year. I tried both methods and no luck. Washers took up some of the slack but not all. Tying the cord set me at 2.5k lol.
I may try advancing to timing a smidge to see if that helps. Other than that what else could I do?
エキサイティングカーレーシングチーム!
post Mar 22, 2012 - 6:27 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Honestly, if your trying to pull slack and nothing has worked thus far, Id go with advancing the timing a bit. Your OBDI so it'll stick. Or if you have access to supplies/personnel you could make a spacer to get rid of that slack....? Personally I adjusted those nuts till my idle was where I wanted it.
post Mar 22, 2012 - 6:29 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Tome for a new cable?
n
Lo-Fi Version Time is now: November 23rd, 2024 - 8:07 AM
