> Hissing noise from under car
post Mar 25, 2012 - 4:29 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
I got a 97 Ceica GT that hisses when it's cold but when it gets warm it stops. It sounds like it's coming from under the car somewhere. I'm thinking it's a leak from the exhaust pipe but if it was then it would've been hissing still even if it was warm right?
post Mar 25, 2012 - 4:32 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Are you sure your not just hearing the intake pulling in air in?
mine with the sri is really loud at start up
94 st hatch my daily driver
n
post Mar 25, 2012 - 8:42 PM
jt1023
Joined Jun 12, '11
From Suffolk County, NY
I get the same thing but its definitely from my intake. The hissing is really noticeable on startup.
However, it could also be a small exhaust leak in your pipe somewhere. The metal pipes expand when they heat up and this could plug a very small exhaust leak and cause the hissing to stop.
post Mar 25, 2012 - 10:00 PM
Syaoran
Joined Jan 4, '12
From US
Hissing? Sounds just like the IACV pulling air when it's cold, then shutting off after it warms up, like it should.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Mar 26, 2012 - 12:25 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (kurt95gt @ Mar 25, 2012 - 4:32 PM) *
Yes I'm sure. I listened carefully all around my car and I can hear it mostly when I'm at the back right wheel by the exhaust pipe. I can also hear it when I'm in the car idling.
QUOTE (jt1023 @ Mar 25, 2012 - 8:42 PM) *
Yea. I was thinking that too.
post Apr 7, 2012 - 10:28 AM
Celigirl
Joined Feb 7, '10
From Tampa, FLorida
i had the same hissing under my rear seat- that was my fuel pump going out- it hisses then goes out- is your car sputtering at all when it first starts to go
post Apr 7, 2012 - 3:40 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Celigirl @ Apr 7, 2012 - 10:28 AM) *
Yea it's like around under my rear seats. I don't understand what you meant as sputters but I do know that it always has condensation out of the tail pipe on cold starts.
post Apr 7, 2012 - 8:05 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Is it a new car?
Could just be the sound of an aftermarket fuel pump.
My Celica!
post Apr 8, 2012 - 2:09 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (jordisonjr @ Apr 7, 2012 - 8:05 PM) *
Is it a new car?
Nope. I bought it from a private owner so it's used.
post Apr 8, 2012 - 12:05 PM
NorthKennedy
Joined Apr 8, '12
From Norway
QUOTE (ILoveMySilly97 @ Mar 25, 2012 - 5:29 PM) *
If it's only when startup/ when it's cold, then I would take a look at the Servo pump or water pump maybe? My servo wheele is making a noise like that when it's cold.. Nothing to worry about though !
post Apr 8, 2012 - 12:34 PM
matts94celica
Joined Apr 20, '11
From College Station, Tx
My water pump made a noise because it was going out but it was a hissing it was a grinding type noise. And you can definitely tell its from under the engine bay so I don't think it's water pump
post Apr 8, 2012 - 4:25 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (NorthKennedy @ Apr 8, 2012 - 1:05 PM) *
Actually the previous owner I bought it from just got the water pump replaced like 4 months ago. So it can't be the waterpump.
post Apr 8, 2012 - 5:25 PM
trdproven
Joined Aug 2, '05
From Guam
if you rev, you can tell if its an exhaust leak or not.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 11, 2012 - 1:48 AM
ILoveMySilly97
Joined Mar 8, '12
EDIT: My car does have bad emission too. It stinks up the whole garage when I turn it on.
Lo-Fi Version Time is now: January 10th, 2025 - 7:24 AM
