> not sure if this is turbo flutter or not..., Video inside.
post Mar 27, 2012 - 9:07 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
hey everyone,
so I'm not sure if this is just a loud sound because of my air intake or if it really is turbo flutter.
The Link
this is staying around 0 to -5 PSI and will make the sound up to just under 5 psi. after 5 psi the BoV fully opens and evacuates quickly.
this was my old turbo before the turbine shaft snapped on the exhaust side.
but the thing is, its doing the same damned thing on the turbo I have on it now. and its been doing it since I installed the turbo.
Thanks,
Kevin
post Mar 27, 2012 - 11:41 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
i would say thats a poor BOV.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 28, 2012 - 12:29 AM
Soulend
Joined Nov 24, '07
From Tucson, Az
QUOTE (Smaay @ Mar 27, 2012 - 9:41 PM) *
I bought my HKS in December and got it early January. it did it with the stock BoV, and the Blitz I had as well. though the Blitz was worn, and I'm guessing the stock one was too...
Kevin
post Mar 28, 2012 - 5:14 AM
the hks will flutter like that with small throttle inputs.
you could tune it out of the older style that have the adjustment screw in the back by tightening the spring.
post Mar 28, 2012 - 9:59 AM
Ted95
Joined Mar 8, '09
From Westport, MA
My hks bov makes a similar sound too under small loads, it's normal. I actually like the sound of it.
st205 powered ss3 coupe
post Mar 28, 2012 - 10:10 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
that sounds a little excessive, check your vacuum lines for a leak it doesnt sound like you have any bov working at all
Mike W
269awhp / 273ft-lbs
post Mar 31, 2012 - 1:04 AM
Soulend
Joined Nov 24, '07
From Tucson, Az
Cool thanks guys. Ill double check the Vac lines, but I'm pretty sure they are fine.
I'll take a video with how its set up now('new' Turbo+HKS). you might hear a difference. this again was with the stock BoV which I think was worn out by then.
Kevin
post Mar 31, 2012 - 9:45 AM
CELL_PROTOTYPE_X
Joined Aug 7, '05
From Columbus OH
Sounds like compressor surge to me...your BOV shouldn't flutter like that after every shift. I had a similar issue when installing the new HKS SSQV so I took it off and kept the my original BOV on. I get some flutter every now and then when cruising at freeway speeds and slightly letting off the throttle but never in between shifts.
Lo-Fi Version Time is now: February 13th, 2025 - 6:15 PM
