> Boggs out then ok?
post Mar 29, 2012 - 8:11 PM
brypoint
Joined Mar 29, '12
From las vegas
Hey guys, I took my 94 ST to power wash the engine compartment as I have done in the past. I keep the engine running while doing this as I've heard it keeps you from cracking the block (not sure how true this is). Anyways when I drove home from the carwash it was bogging while hitting the gas and then it would sorta pop back into regular mode after say 3k rpm. I thought maybe I got a little water in the intake as it was high pressure water. I let it sit and drove it the next day and it seemed alot better.
Well today I took it out on the highway for around 30 miles one way it was working fine but when I got off the highway the bogging started up again and lasted the whole way home. I checked for any vacuum lines that may of popped off and inspected spark plug wires and such all seemd good and tight. I looked at the oil just to be sure their wan't water in there and it was nice and clean, I also checked in the airbox and that was all dry too.
I'm baffled, anyone have any ideas what I should look for or what else I can check? I'm going to pull all the spark plug wires and plugs, and inspect the distributer cap for water but other then that I dunno.....
Update: I reset the ECU as per this forums and no change....Also the check engine light isn't on.
This post has been edited by brypoint: Mar 29, 2012 - 8:14 PM
post Mar 29, 2012 - 10:19 PM
Box
Joined Feb 23, '12
From Warrior, AL
Something with the fuel system perhaps?
2001 Miata LS 5-speed
post Mar 29, 2012 - 11:12 PM
brypoint
Joined Mar 29, '12
From las vegas
Yup im retarded, got water in the Plugs. Fixed it quick though lol.
post Mar 30, 2012 - 12:04 AM
Box
Joined Feb 23, '12
From Warrior, AL
Well, at least it was an easy fix. Also, steam tends to work better at removing grime. If anywhere local has a steamer, should use it instead.
Lo-Fi Version Time is now: December 2nd, 2024 - 2:58 PM
