> Thump sound when powering into lefts, What could it be????
post Apr 9, 2012 - 12:29 AM
injection
Joined Jan 10, '11
From Trail BC
Hey guys, so I've done my 3rd gen 3sgte swap and kept the 5sfe front wheel drive tranny, I believe it's the s54 transmission I think???
Anyway, when taking lefts, I am noticing a thump thump thump sound coming out of my front driverside quarter....I noticed it only does it when powering into/through a left turn????? Speed is also a factor, if pulling away from a stop sign, the thump sound is slow, because your just starting out I'n motion, if going down the highway at 160kmh, it sounds like an angry woodpecker! When going into lefts, I have pulled/pushed on components trying to find something suspect, but everything seems snug and tight....Mind you, I actually havn't jacked up the car, and tried moving the wheels back n fourth, to see if it's a balljoint, Any other ideas of what this could be fellas? Thanx big time
Josh
post Apr 9, 2012 - 2:45 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
It almost certainly has to be a driveline component, anytime the noise is affected by rpm.
I would suspect the CV axle, check and make sure the boots on it are completely intact. Also possible but unlikely would be the hub assembly.
You can buy a remanufactured CV axle with a lifetime warranty for $60 (there is an additional $60 charge if you dont give em the old one) since it is the stock transmission. The driverside is a little harder to change because it has a snap ring that holds it in the differential so a good prybar is a necessity. You might want to change both sides out if you want to be proactive, but you by no means have to or need to.
Lo-Fi Version Time is now: November 23rd, 2024 - 3:37 AM
