> jdm Projector, question about installation
post Apr 9, 2012 - 8:03 PM
marinos
Joined Aug 17, '10
Hi guys
I have a jdm RHD 94 celica and I am thinking to buy jdm clear projectors.
Is the wiring just plug on or the connectors will be different.
I know I will need the electronic unit for the projectors but I don't know much details.
post Apr 10, 2012 - 1:51 AM
trdproven
Joined Aug 2, '05
From Guam
what electronic unit, HIDs? If you are currently on H1 bulbs, no conversion, if you are not, you gotta do some wiring.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 10, 2012 - 3:43 AM
UndaGrwnD
Joined Dec 16, '11
From The Netherlands
http://www.6gc.net/forums/index.php?showtopic=69958
see there for HOW-TO
post Apr 10, 2012 - 8:08 AM
marinos
Joined Aug 17, '10
QUOTE (trdproven @ Apr 10, 2012 - 2:51 AM) *
Thanks for your respond.
My headlights are all stock I never changed any of the bulbs since I bought the car, I don't know a lot about bulbs
and I don't care really how bright will be or not.
I am happy the way my headlights work at night so I only wan't the jdm for better look, so do you think I will need any wiring?
Or is it possible to use the existing bulbs in a jdm projector?
This post has been edited by marinos: Apr 10, 2012 - 8:18 AM
post Apr 10, 2012 - 9:09 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
You may just need to get different bulbs, because the stock are 9005 for the high beams, and I'm pretty sure the JDM high beams are a different bulb size (Check the electrical/lightint stickies, it will say which bulb in there)
But if the JDM highs do use a 9005 like the USDM highs, then it will simply be plug and play, no need to change any wiring.
My Celica!
post Apr 10, 2012 - 2:15 PM
richee3
Joined Jun 29, '08
From Denver
You can plug your high beam bulbs in with no issues. The low beams use a different bulb- they use an H1 bulb instead of a 9006. You will need to either cut and splice your wiring to an H1 connector or make a plug and play wiring harness, as posted in the link provided.
http://www.6gc.net/forums/index.php?showtopic=81270
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Apr 16, 2012 - 2:29 PM
marinos
Joined Aug 17, '10
Thanks guys!!!!
Lo-Fi Version Time is now: January 10th, 2025 - 12:32 PM
