![]() Enthusiast ![]() Joined Jul 2, '11 From Lancaster, PA Currently Offline Reputation: 0 (0%) ![]() |
Hey guys im new to 6gc and i have a few questions...
I have been searching for 2-3 weeks on info on the 3sge Beams Red Top Swap into my ST204 5 speed GT and from what i understand everything just drops right in place of the 5sfe (correct me if im wrong). My main concern is wiring! Is the swap plug n play? Or will i need to purchase an engine w/ harnes and ecu? Reason for the swap: I just picked up my st204 for 650$ With 126k Miles minimal rust and a 8/10 body and completly stock but it has a snapped timing belt Reason for choosing 3sge: I want an engine swap that has the power when i need it and the mpg of a N/A engine. -------------------- 1994 ST204- 5sfe Currently being rebuilt 1994 AT200-Awaiting Build |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) ![]() |
You will need the engine harness & ECU from a Red Top.
You will need the engine harness & ECU from a Red Top. ![]() Thank you KAOS! Will i still be able to keep AC/Cruise/PS? -------------------- 1994 ST204- 5sfe Currently being rebuilt 1994 AT200-Awaiting Build |
You will need the engine harness & ECU from a Red Top. ![]() Thank you KAOS! Will i still be able to keep AC/Cruise/PS? I believe so - I plan on trying to keep that stuff too in my 3SGE swap. -------------------- |
You will need the engine harness & ECU from a Red Top. ![]() Thank you KAOS! Will i still be able to keep AC/Cruise/PS? I believe so - I plan on trying to keep that stuff too in my 3SGE swap. Great! Thanks for the fast response and useful info! Much luck to you and your swap also This post has been edited by Jaytwou2: Apr 12, 2012 - 1:46 PM -------------------- 1994 ST204- 5sfe Currently being rebuilt 1994 AT200-Awaiting Build |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) ![]() |
yea you will be able to. atleast thats how it is on my car.
yea you will be able to. atleast thats how it is on my car. Are you saying its plug n play? No need for JDM harness and ecu? -------------------- 1994 ST204- 5sfe Currently being rebuilt 1994 AT200-Awaiting Build |
I think he was talking about the power steering and ac. You'll need the harness and ecu for the Beams.
I think he was talking about the power steering and ac. You'll need the harness and ecu for the Beams. Ok, Thanks! -------------------- 1994 ST204- 5sfe Currently being rebuilt 1994 AT200-Awaiting Build |
BEAMS sounds like the engine for you. Parts can be difficult to source but not too bad. Give me a little bit and I'll post the wiring up for you.
Edit: -EA1 plug, pin 17 goes to pin 4. Pin 17 is the bottom left wire, red with a black stripe. Pin 4 is the thick black wire at the top center of the EA1. Pin 17 needs power when pin 4 has it. This gives the BEAMS spark. -EA1 plug, pins 2 and 12 need to be bridged. Those are ground wires. They need to be spliced together. There should be two wires, parallel to each other. Just bridge them together. -Clutch start wire- there are 3 vertical plugs next to the ECU. On the body side of the plugs, you have a white (19 pin) plug, light gray (13 pin) plug, and dark gray (17 pin) plug. The clutch start wire is pin 18 on the white plug. Move it to pin 17 on the dark gray plug. -Cruise control: Contrary to popular belief, no work is necessary for cruise control. It's a standalone system with no wiring related to the motor. -To get your airbag light to function properly, you run a wire from the EA1 plug to the light gray interior plug (either pin 4 or pin 5, I have read separate posts saying both and I chose not to do this step so I cannot confirm which pin it is. Useful links: njccmd2002- "I Swapped 3s-ge Redtop Into '97 Limited Edition Vert." turnip- "Swap: 3sge Beams into 94 GT" hurley97/Batman722- "New Addition to Our Family" erahman85- "One acronym... BEAMS" This post has been edited by richee3: Apr 12, 2012 - 2:48 PM -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
BEAMS sounds like the engine for you. Parts can be difficult to source but not too bad. Give me a little bit and I'll post the wiring up for you. Edit: -EA1 plug, pin 17 goes to pin 4. Pin 17 is the bottom left wire, red with a black stripe. Pin 4 is the thick black wire at the top center of the EA1. Pin 17 needs power when pin 4 has it. This gives the BEAMS spark. -EA1 plug, pins 2 and 12 need to be bridged. Those are ground wires. They need to be spliced together. There should be two wires, parallel to each other. Just bridge them together. -Clutch start wire- there are 3 vertical plugs next to the ECU. On the body side of the plugs, you have a white (19 pin) plug, light gray (13 pin) plug, and dark gray (17 pin) plug. The clutch start wire is pin 18 on the white plug. Move it to pin 17 on the dark gray plug. -Cruise control: Contrary to popular belief, no work is necessary for cruise control. It's a standalone system with no wiring related to the motor. -To get your airbag light to function properly, you run a wire from the EA1 plug to the light gray interior plug (either pin 4 or pin 5, I have read separate posts saying both and I chose not to do this step so I cannot confirm which pin it is. Useful links: njccmd2002- "I Swapped 3s-ge Redtop Into '97 Limited Edition Vert." turnip- "Swap: 3sge Beams into 94 GT" hurley97/Batman722- "New Addition to Our Family" erahman85- "One acronym... BEAMS" Wow thanks for all the great info! I am guessing the ea1 would be vvt solenoid? -------------------- 1994 ST204- 5sfe Currently being rebuilt 1994 AT200-Awaiting Build |
no the vvt solenoid is different, from the EA1 plug. I posted the pic of each in my thread.
I posted pictures too, but I opted out of posting them here to avoid too much initial confusion.
EA1 plug, pins 4 and 17 bridged, as well as 2 and 12. ![]() ![]() ![]() Clutch start wire: ![]() -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
The airbags should be on there own separate system. I took all the wiring out in my car and nothing ever went to the ECU.
Can i avoid all the wiring issues with replacing the USDM harness with a JDM harness and ECU?
No. The wiring changes I posted are the changes that need to be made to the JDM wiring harness.
Enthusiast Joined Nov 26, '14 From United States Currently Offline Reputation: 0 (0%) ![]() |
Hey 6gc, ive messaged a couple of you and no response, i know this is an old post but im in the process of doing my BEAMS swap and need some help from you vets
![]() New member here and after extensive reading on the forums for the past couple months I still have a few issues with my 3sge Beams Red Top swap. So, some background on the status here, have a 96 Celica GT st204 which had a 5sfe, bone stock. Back over summer bought a 98 3sge Beams Redtop approx 50k miles. We did all the major maintenance, timing belt, water pump, spark plugs, belts, fluids etc. The motor is currently installed in the car. However the car does not start, as in the starter wont even turn. Dash lights up and everything but starter wont turn. My guess is its the clutch start wire. The issue now is that we tried to follow the wiring directions posted on this website, BUT the issue lies with the 3 vertical plugs that are mentioned. The clutch start wire is supposed to be a black with yellow stripe coming from the one of these plugs right? In the pictures shown, there must be at least 15 or so wires coming from the white plug. But on my engine harness that same plug only has 4 or 5 wires coming from it and has no black with yellow striped wire. Matter of fact, there is NO black with yellow striped wire on this harness. Thats my first issue. Now since that was the case, there was still a solid black wire coming from the pin 18 location on the white plug as shown in the picture, so we moved that wire to the pin 17 location on the dark grey plug as described in the directions. (obviously that did not fix the issue) Not even sure if that is the issue. This was the only part that did not match the directions, all the wiring directions were spot on, and we took care of those, its just the clutch start wire and plug that was different. Could you help walk me through this? Your help would be very much appreciated! Thanks |
Was your car a standard or auto ?
I got your PM, but I just now have some time to respond. Can you post pictures of your plug? You mentioned in the PM that my picture had several wires, but your plug only has a few. The harness I snapped a picture of was from an auto trans, so it had some extra wires that a manual trans harness doesn't have. Both harness should have the black/yellow wire in the same spot though. However, if your BEAMS harness came on an auto trans, there's one extra step necessary before the car will crank. If the harness is from a manual trans, it should be as simple as moving the wire.
Was your car a standard or auto ? The engine came with a manual trans with LSD. I got your PM, but I just now have some time to respond. Can you post pictures of your plug? You mentioned in the PM that my picture had several wires, but your plug only has a few. The harness I snapped a picture of was from an auto trans, so it had some extra wires that a manual trans harness doesn't have. Both harness should have the black/yellow wire in the same spot though. However, if your BEAMS harness came on an auto trans, there's one extra step necessary before the car will crank. If the harness is from a manual trans, it should be as simple as moving the wire. Heres the plug off my 3sge motor. Theres the black wire in pin 18. its black but no yellow stripe |
Lo-Fi Version | Time is now: March 20th, 2025 - 10:09 AM |
