look, trace that wire, use a multimeter, toyota is known to change the wire coloring in some years, you will have to test, with a multimeter... look for the clutch switch, check for continuity.
Enthusiast Joined Nov 26, '14 From United States Currently Offline Reputation: 0 (0%) ![]() |
![]() Heres the plug. I will trace the black wire and check for continuity and let you know what i find. |
These plugs are off the BEAMS harness and are now located on the passenger side down by the kick panel, can someone pls tell me what they connect to? The USDM harness did not have these
Lo-Fi Version | Time is now: March 20th, 2025 - 9:57 AM |
