what happen to my clutch ? ( anwsered), thank for help |
Apr 13, 2012 - 1:32 PM |
Enthusiast Joined Nov 18, '10 From montreal Currently Offline Reputation: 0 (0%) |
i was on the street yester day and its starting smelling burn , and i heard a noise like `>ping> and the clutch stop working,
so i drove the car in 2nd gear to home, at neutral: if i push the clucht, -feel loose, but the pedal come back -when i push the clutch , the rpm goes downs and almost shut down the engine, what happen ? do i have to get a new clutch or a new cylinder clucht? do i have to open the tranny? thanks This post has been edited by Needles: May 9, 2012 - 6:32 PM |
Apr 13, 2012 - 8:04 PM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
so your clutch is working backwards? engaging when you push the pedal???
can you drive the car at all? -------------------- |
Apr 13, 2012 - 10:02 PM |
Crank walk.
This post has been edited by trdproven: Apr 13, 2012 - 10:19 PM -------------------- 94 Celica GT
Apr 13, 2012 - 11:38 PM |
Apr 14, 2012 - 12:29 AM |
any leaks or some type of failure in the hydraulics? tob problem? its somewhere in line between pressing your pedal to the clutch system.
This post has been edited by trdproven: Apr 14, 2012 - 12:40 AM -------------------- 94 Celica GT
Apr 14, 2012 - 1:10 PM |
Enthusiast Joined Mar 8, '10 From Great White North Currently Offline Reputation: 3 (100%) |
Apr 14, 2012 - 5:58 PM |
I could use a better description of the problem here, maybe make a video of it if you can.
Im thinking something may be wrong with the fingers or throwout bearing. Are there any noises? Or does it simply die when you push in the clutch? Maybe the spring on the fork came fell out(theres the ping noise and clutch failure) and its wedging into clutch somehow, causing the loose pedal feel. It definately sounds like your going to be pulling the clutch soon, if you need some pointers were here to help. |
Apr 22, 2012 - 10:33 PM |
Enthusiast Joined Jun 5, '07 From Santa Maria Currently Offline Reputation: 1 (100%) |
For a second there I had to make sure I wasn't on a DSM forum -------------------- |
Apr 23, 2012 - 1:49 PM |
i doubt its crank walk
Apr 23, 2012 - 2:28 PM |
Apr 23, 2012 - 5:19 PM |
i doubt its crank walk im not sure if 5sfe is prone to this, i just know its a symptom thats known for crank walk. just throwing ideas out there. what about broken clutch springs? This post has been edited by trdproven: Apr 23, 2012 - 5:20 PM -------------------- 94 Celica GT
Apr 23, 2012 - 6:37 PM |
i doubt its crank walk im not sure if 5sfe is prone to this, i just know its a symptom thats known for crank walk. just throwing ideas out there. what about broken clutch springs? Last time he was active was the day after he posted the topic(his second post here), so we will prolly never know. But based on the OP's post it sounds like something catastrophically failed because it failed so suddenly and he heard noises. To my knowledge crankwalk would be a progressive failure not an instant one. This post has been edited by Special_Edy: Apr 23, 2012 - 6:39 PM |
Apr 23, 2012 - 7:17 PM |
srry for long time no reply,
i just think ist the clutch bearing that burn up, because when i swapped, (i have 3sgte and mr2 tranny) i forgot to put grease on the bearing, after i changed my thermosthat and for the first time since my swap, the engine get heat (up to normal temp, ) and the bearing just burn two day after, cause no grease into it, i think its what happend, and now need to remove the transmission and change the bearing no leak from clutch master This post has been edited by Needles: Apr 23, 2012 - 7:28 PM |
Apr 23, 2012 - 7:43 PM |
do you get a loud high pitched sound? that would be the TOB.
This post has been edited by trdproven: Apr 23, 2012 - 7:43 PM -------------------- 94 Celica GT
Apr 30, 2012 - 11:41 PM |
May 3, 2012 - 2:32 PM |
do you get a loud high pitched sound? that would be the TOB. i had time to check the car today, i start it and smell burn after 5 sec, when i push the clutch , i heard a high sound like, iieieeeeeeeeeeeeeekkkkkkkkkkkkk, so i turn it off cause the smell, im about to took off the front crossmember and the tranny, if i know what piece i have to order before, it will help me a lot what is the tob ? This post has been edited by Needles: May 3, 2012 - 2:32 PM |
May 3, 2012 - 2:53 PM |
Enthusiast Joined Apr 22, '12 From Central NY Currently Offline Reputation: 5 (100%) |
Sounds like springs to me as well. Could be the TOB (Throw out bearing)
-------------------- 99 Celica GT-S
91 Subaru Legacy Sport AWD Turbo 2010 Acura RDX Turbo w/ Technology Package 68 Impala SS Convertable |
May 3, 2012 - 3:12 PM |
The throw-out bearing is wedged up against the input shaft by a fork. You'll see it once you separate the transmission.
This post has been edited by SwissFerdi: May 3, 2012 - 3:12 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
May 3, 2012 - 3:25 PM |
OOOoooOOOOo that smell...yea thats your clutch cooking.
Game over, get in there and find the exact issue! |
May 8, 2012 - 2:09 PM |
Answer:
The throw out bearing likely went bad. That's very common. But before you condemn it, get someone to operate the pedal while you observe the clutch lever at the bell housing. If the lever fails to move or moves little, check for fluid in the master cylinder. If there is a low fluid level top it up. You may have to bleed the system. If still no movement suspect the clutch master cylinder. If fluid is dripping from the bell housing or clutch cylinder the slave cylinder needs re-sealing/replacing. If all appears normal, there is a phosphor-bronze bushing in the centre of the flywheel (the throw out bearing) which can seize onto the gearbox input shaft. i just found that anwser very useful, but what about the clinkkkk sound ive heard when the tob seize ? what can it be, one spring on the clutch ? suggestion ? should i buy a new clutch, or do i need to buy all the clutch setup whit pressure plate and flywheel This post has been edited by Needles: May 8, 2012 - 2:12 PM |
Lo-Fi Version | Time is now: December 3rd, 2024 - 11:51 PM |
