> i need a ecu and wiring harness
post Apr 14, 2012 - 2:33 PM
stormmage88
Joined Feb 29, '12
From mississippi
im looking for a ecu and wiring harness for a 7afe m/t
my old ecu part number is 89661-2b770, 175700-5631, 12v
my old harness and ecu burned up and i need to replace it
if you have one you can call or text me at 601-678-6687
my car is a 1995 toyota celica st 5 speed
post Apr 14, 2012 - 4:11 PM
BoostedRicer
Joined Apr 2, '11
From Gloucester/804
QUOTE (stormmage88 @ Apr 14, 2012 - 2:33 PM) *
will a ecu out of a 94 st 5 speed work? if so, i got one. text me 757 448 7862
This post has been edited by BoostedRicer: Apr 14, 2012 - 4:12 PM
post Apr 14, 2012 - 7:00 PM
stormmage88
Joined Feb 29, '12
From mississippi
QUOTE (BoostedRicer @ Apr 14, 2012 - 5:11 PM) *
i do believe it will work if you can pull out the wiring harness and ecu it really would help me how much would you want for it ?
i just rebuilt my 7a and im not getting any fire... i belive it to be the ecu or wring harness frown.gif it makes me mad hopefully this will fix it
post Apr 14, 2012 - 7:04 PM
BoostedRicer
Joined Apr 2, '11
From Gloucester/804
QUOTE (stormmage88 @ Apr 14, 2012 - 8:00 PM) *
Well are you the one who texted me? The wiring harness off my car, the only thing thats wrong with it is the altenator plug i cut, but still have plug...can be rewired and tapped back together. It was a boosted car, so some wires from the harness that plugged into the ecu were ran into wires from the AFC Neo. I think they are free open...maybe some plastic clips aren't perfect. I'll have to overlook everything and see if I can find anymore errors in the harness for ya and make sure its in okay enough shape to use.
As far as the ecu is concerned, I know that works fine. Once i figure out the wiring harness and check it as okay, i'll let you know the price on everything. Just give me like until Monday to check mine out. Im not home at the moment. Sound okay?
Lo-Fi Version Time is now: December 4th, 2024 - 3:03 PM
