WTB: Stock auto shifter |
Dec 29, 2003 - 9:44 PM |
Enthusiast Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
Yea well I was going to install a new shifter and boot today, and instead of cutting the O/D wire off fron the bottom I tried to take the button of first...so then I pulled it out causing the wires to rip off from inside the switch! So I got PO'd and I coudnt fix it so now I need a new O/D thing and I don't know if I should go to the dealership or if anybody has the assembly lying around, I need it NOW If not I will be shot !
Jan 1, 2004 - 12:40 AM |
Enthusiast Joined Apr 29, '03 From Davenport, IA Currently Offline Reputation: 0 (0%) |
I will have one for sale in a few weeks. I'm doing a 3sgte st185 swap and converting to manual. So if you can wait I can sell you mine for cheap. PeaCe
Jan 2, 2004 - 1:14 AM |
I don't understand what you did. If the OD isn't working, you can take the lower dash panel out and splice the wires you need to splice together. That will make the OD stay on all the time. If you want to make it turn on and off, re solder the wires onto the stock assembly, or go to wall mart and buy a two way switch. It's no problem, trust me.
Lo-Fi Version | Time is now: December 1st, 2024 - 9:19 PM |
