![]() Enthusiast ![]() Joined Feb 1, '12 From The Colony, TX Currently Offline Reputation: 1 (100%) ![]() |
they havent worked since i bought my car, i didnt know what the heck to do, so i just left them like that, but now its getting annoying, what could be the problem? has new bulbs, so dont ask, thanks before hand
could be a sensor on the transmission that went bad.
![]() Enthusiast ![]() ![]() ![]() Joined Feb 12, '06 From Fresno CA Currently Offline Reputation: 1 (100%) ![]() |
could be a sensor on the transmission that went bad. +1 buddy has a 86 supra and the senor came off plug it in again and work. -------------------- |
Should be right on the topside of the transmission. Find it first and go from there.
Edit: It's about $25 from autozone for the back-up light switch. This post has been edited by mkernz22: Apr 24, 2012 - 2:20 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
check your fuse and also the harness on top of your transmission, just in case, its not the ground wire. its the one with an actual harness connector by itself. dont look for it with all those wires bundled up with the starter thats not it. should be fairly easy to find.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) ![]() |
Should be right on the topside of the transmission. Find it first and go from there. Edit: It's about $25 from autozone for the back-up light switch. When I first bought it. The left one worked but the right one didn't. So I decided to replace them both and then both didn't work. I put in both the old ones and both still didn't work. Now it just doesn't turn on anymore. Can anyone get me a pic of it? I have the same exact problem but I can't seem to find it on my tranny. My car info is on my signature. This post has been edited by ILoveMySilly97: Sep 3, 2012 - 9:42 PM -------------------- |
Back up lamp switch what it be called.
So how do you test it if it's good or bad? I heard of the jumping method. Where you jump the two wires on the switch. Can anyone tell me how to do this method properly? Like do I have to turn my key to on and then jump it? Do I have to put my gear into REVERSE? Or what? Also I have a 5spd if it matters.
Should be an ohm rating for it somewhere. Would find for sure in the shop manual, possibly somewhere online too.
check too since you mentioned 1 light goes on and the other doesnt sometimes you have a bad socket(S) or wiring. if youre fuse is good, im leaning towards the between the wiring from the tranny to the actual bulb sockets. sometimes they go bad, corrode, or stick together, or whatever.
This post has been edited by trdproven: Sep 4, 2012 - 5:23 AM -------------------- 94 Celica GT
What I know for sure is that my bulbs are good because I switch the turn signals and my reverse light bulbs and the bulbs work. The next thing I'm going to do is have my friend inspect the re-wiring that was done by the previous owner. Might've done a ****ty job on re-wiring on something.
What I know for sure is that my bulbs are good because I switch the turn signals and my reverse light bulbs and the bulbs work. Also checked my fuse and it wasn't blown. The next thing I'm going to do is have my friend inspect the re-wiring that was done by the previous owner. Might've done a ****ty job on re-wiring on something. -------------------- |
shouldn't take you long to check the wiring, good luck, im sure you'll get it working.
Decided to replace the reverse lamp switch and it solved the problem. Now my reverse lights are working again. It was hecka hard trying to get to it. It was in an awkward spot where you can't get it out with a wrench or a deep socket. But I got around it and got it replaced.
Huzzah!!!
Enthusiast Joined Nov 17, '12 From NM Currently Offline Reputation: 0 (0%) ![]() |
Decided to replace the reverse lamp switch and it solved the problem. Now my reverse lights are working again. It was hecka hard trying to get to it. It was in an awkward spot where you can't get it out with a wrench or a deep socket. But I got around it and got it replaced. ![]() Question for "ILoveMySilly97": What tool did you use to change this switch out and what other components did you have to remove? I'm at a loss. I tried every idea at our base auto hobby shop and nothing worked because of the tight location and the main wiring harness being directly above the switch. Thanks. |
I don't know if you received my message but here it is again to help everyone else who runs into this problem.
Honestly. I believe I got lucky on this one. The extension bar I used was a 1/2" extension bar that got twisted and bent a bit from a previous use. So it was angled where it was barely enough to grip the sensor. It's a tough spot to get to. I'd recommend you use ratchet with a SWIVEL SOCKET or a SWIVEL EXTENSION. It helps you get pass through these ugly angles. Here's a link to what I'm talking about if you don't know what SWIVELs are. Just a FYI. it should be fairly easy to loosen up. Shouldn't be on their so tight. http://s.ecrater.com/stores/67508/483a4f5b5fcba_67508n.jpg This post has been edited by ILoveMySilly97: Nov 24, 2012 - 11:38 AM -------------------- |
Lo-Fi Version | Time is now: February 22nd, 2025 - 4:07 AM |
