Enthusiast Joined Feb 10, '11 From Montreal,QC Currently Offline Reputation: 0 (0%) ![]() |
Hi everyone,
I run a relatively stock ST185 RC and i swapped the electronics(Map, igniter, injectors, and ECU) for the MAP processed ST205 setup. Now as you may know, i ran into code 54 error because of the intercooler pump error....I tried the relay method with the resistors and grounded the LEV at the ECU too but i still get the code while driving...Anyone one has other methods or suggestions to cure that error code please.... Thanks for the help, Mathieu |
![]() Enthusiast ![]() ![]() ![]() Joined Dec 9, '08 From Blainville Currently Offline Reputation: 4 (100%) ![]() |
Hi everyone, I run a relatively stock ST185 RC and i swapped the electronics(Map, igniter, injectors, and ECU) for the MAP processed ST205 setup. Now as you may know, i ran into code 54 error because of the intercooler pump error....I tried the relay method with the resistors and grounded the LEV at the ECU too but i still get the code while driving...Anyone one has other methods or suggestions to cure that error code please.... Thanks for the help, Mathieu Make sure the IC if filled to top with coolant. All I had to do with mine was add just a little coolant and the code disappeared. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) ![]() |
Make sure the IC if filled to top with coolant. All I had to do with mine was add just a little coolant and the code disappeared. Exactly. Also will help to reset all saved codes by disconnecting battery or pulling the ECU fuse for 30 seconds. -------------------- No more replicas... This is evolution... This is SS-four :)
![]() ________[Featured Celica of 6gc.net @ 2010]_________ |
Lo-Fi Version | Time is now: February 22nd, 2025 - 9:20 AM |
