Enthusiast ![]() ![]() Joined May 2, '06 From Nevada Currently Offline Reputation: 0 (0%) ![]() |
Installing a pressure gauge - anyone tried this adapter to keep the stock switch and add a pressure sender?
http://208.109.215.220/files/gauge.pdf Is it strong enough (it seems to be made of steel) to hold both safely? Many of ass who tried brass tees know the problem and in case of breaking - well, is the oil... |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) ![]() |
Whats wrong with a brass T? I doubt your getting higher oil pressure than the city tap's waterpressure(which is what its designed for). And even if the T did break the first thing to lose pressure would be the idiot light and oil pressure guage. So you would know before any engine damage took place
Engine vibration on extended leverage of a soft metal - brass = highly likely breakage VERY soon (not caused by the pressure but it will add to it)
True, you will notice immediately, but hardly convenient if happens at a highway speed on a road trip... Whats wrong with a brass T? I doubt your getting higher oil pressure than the city tap's waterpressure(which is what its designed for). And even if the T did break the first thing to lose pressure would be the idiot light and oil pressure guage. So you would know before any engine damage took place |
Well, perhaps there is more than one place on our blocks to read pressure from. Most engines have plugs over the oil galleries in a few spots so I guess its worth checking into
Lo-Fi Version | Time is now: February 21st, 2025 - 7:19 AM |
