> clutch problem.
post Apr 29, 2012 - 2:18 PM
Yesaccelica
Joined Apr 18, '12
From illinois (USA)
I just replaced my clutch so i went for a test drive to see if everything is goooood. The problem is that the clutch is not completely disengaging. Does anyone know maybe what i did wrong or if anyone knows how to fix this PLEASE tell me how.
post Apr 29, 2012 - 3:42 PM
rave2n
Joined May 29, '09
From Gainesville, FL
as in the pedal doesn't come back up, or it never engages...for instance you hit the gas, RPMs fly up...or does it slip up?
Have you checked your hydros for such clutch line? Did you bleed the slave? Did you check to see if the trannie fork is moving the bearing...?
Start there...
This post has been edited by rave2n: Apr 29, 2012 - 3:42 PM
post Apr 29, 2012 - 4:48 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
did you open the system? have someone watch the slave cylinder while you pump the clutch. see how much it moves
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Apr 29, 2012 - 5:13 PM
Yesaccelica
Joined Apr 18, '12
From illinois (USA)
I have to start the car in gear and even with the clutch pressed all the way in, it moves forward. I did bleed the slave and the trannie fork is moving the bearing
Lo-Fi Version Time is now: January 10th, 2025 - 12:25 AM
