I has a car, Updated 11/1/2015 - Nothing of note. |
Apr 30, 2012 - 1:49 AM |
Enthusiast Joined Apr 30, '12 From Wellington, NZ Currently Offline Reputation: 0 (0%) |
Oh hi.
I've been lurking here for a while for the wealth of motivation in the build threads and such. I has a '96 GT4. Being in NZ, it is a JDM facelifted one - no trispokes here, though unfortunately noone in the car's past ever thought to pick up projectors. It currently looks like this: Anyway, hi, sup etc. Oh, I have a build thread here, and am much too lazy to cross-post everything! http://www.gpforums.co.nz/showthread.php?threadid=435792 This post has been edited by Anoroc: Jan 11, 2015 - 5:47 AM |
Apr 30, 2012 - 2:01 PM |
Enthusiast Joined Dec 9, '08 From Blainville Currently Offline Reputation: 4 (100%) |
Nice build! Looks very good and clean!
I wanted to change my spark plugs too and I wondered how I had to deal with the IC. Thanks for the info! I'm just curious though, coolant won't come out when you take the IC out? |
Apr 30, 2012 - 3:27 PM |
You don't actually remove it - you just take it from the intake mani and turbo and bend it out of the way - there's about 80 degrees of movement in it, definitely more than enough to get the plugs out.
The things you learn This post has been edited by Anoroc: Apr 30, 2012 - 3:27 PM |
Apr 30, 2012 - 3:28 PM |
Welcome to the forum Looks like a good clean car!
May 1, 2012 - 3:42 AM |
You don't actually remove it - you just take it from the intake mani and turbo and bend it out of the way - there's about 80 degrees of movement in it, definitely more than enough to get the plugs out. The things you learn Ohhhh I see what you did there. Nice tip! Thanks! |
May 6, 2012 - 10:31 PM |
Or you can just... set up an FMIC!
-------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
May 7, 2012 - 2:31 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
Hi great to see another NZ'er join
let me know if you want this thread moved into the my project section -------------------- |
May 7, 2012 - 6:42 AM |
Enthusiast Joined Apr 15, '11 From Auckland, NZ Currently Offline Reputation: 0 (0%) |
Yay another gt4 owner, Checked out your log, very handy about the spark plugs as im doing it this weekend, is your old exhuast for sale?
May 7, 2012 - 1:35 PM |
Yay another gt4 owner, Checked out your log, very handy about the spark plugs as im doing it this weekend, is your old exhuast for sale? It will likely be, but the problem is I'm not sure when! I've decided to bite several bullets and go 3" mandrel SS from the turbo back, which will cost more money than I currently have, so i'm not sure when the current system will be free. I'm not sure how they 'did' the 2.5" system currently there either, since its not a larger diameter copy of the OE system, so it might be a little awkward. I'll post it up here before putting it on trademe at any rate. |
May 8, 2012 - 6:13 AM |
Yea the stock one is i think 2 and 1/8 or slighty bigger and is semi free flow only real problems with it are the rear muffler and the cat/downpipe. What pads do you run? gota love the brakes
May 8, 2012 - 3:22 PM |
Thats a good question, I have no idea! I'm presuming some slightly ghetto-spec ones based on the previous owner. They seem to still have plenty of meat on them, so I won't find out for a while.
(Could this thread be moved to projects pretty please?) Might as well start posting updates to here, means I feel like i'm actually contributing. After work this week, i've been doing this: Which has resulted in this: |
May 9, 2012 - 1:53 AM |
done
is that arm for stereo factory fitted? -------------------- |
May 9, 2012 - 1:56 AM |
Glow in the dark rims? Cool.
May 9, 2012 - 2:44 AM |
Nah, it was put there for the previous headunit, just screwed into the steering sheath, but it works with my new one which is great - its fantastic for lazy people - only a 5cm movement, rather than a 25cm one!
Glowing wheels finished, clear and all: |
May 9, 2012 - 12:14 PM |
Can't wait to see them on the car at night!
May 10, 2012 - 12:23 AM |
May 10, 2012 - 12:34 AM |
Bet that looks just badass going down the road at night.
May 10, 2012 - 8:02 AM |
Enthusiast Joined Nov 18, '10 From montreal Currently Offline Reputation: 0 (0%) |
hi,
your car is certainly really clean and look very good, i assume that is a test whit the rims, look good at night, but i dont feel the white of the rim, whit the paint white of the car, doesnt look the same |
May 10, 2012 - 12:26 PM |
Oh no, its not - and I never expected it to be. Glow in the dark is always a snotty green!
The point of it is the violently glowing green at nighttime |
May 11, 2012 - 12:51 AM |
Changed the oil with some Penrite 0w50 for the second time.
Appears that my first time was abnormally slow - now that I know what to undo (4 bolts to remove a plastic guard), and the drain plug and filter aren't welded directly to the sump, it took all of about 20min. The slowest part was waiting for it to drain. Picture taken while waiting for it to drain. |
Lo-Fi Version | Time is now: November 26th, 2024 - 11:20 PM |
