> 97 Toyota Celica GT electrical problems
post Apr 30, 2012 - 8:40 PM
celica_boi
Joined Dec 10, '08
From Crescent City
Hi there,
I need help with my car. My power windows, gauge light, and the interior accessories doesn't work. The back light don't work but when i step on breaks the break light works. The fan doesn't come on so the radiator gets hot. I bought a new alternator but it didn't make any changes. Any suggestions?
post Apr 30, 2012 - 9:34 PM
Xander_X
Joined Apr 22, '12
From Central NY
Check all your fuses and relays ... ALWAYS do this with electrical before you go buy parts.
99 Celica GT-S
91 Subaru Legacy Sport AWD Turbo
2010 Acura RDX Turbo w/ Technology Package
68 Impala SS Convertable
post Apr 30, 2012 - 9:44 PM
Box
Joined Feb 23, '12
From Warrior, AL
^That. Can get a fuse checker for cheap. Most fuse multi-packs come with one these days anyway. If you don't have one and have a multi-meter, can use that to check for continuity on the fuses. If you don't have a multi-meter, you'll need one anyway for checking electrical components.
2001 Miata LS 5-speed
post Apr 30, 2012 - 9:51 PM
Xander_X
Joined Apr 22, '12
From Central NY
Remember there are 2 fuse panels. Relays you can check easily. Listen for a click when you activate it. If it doesn't click, it's most likely bad. If it clicks, well that doesn't mean it's necessarily good; it might not be making a connection. Swap one in from another circuit that you KNOW works.
99 Celica GT-S
post Jun 7, 2012 - 9:37 PM
celica_boi
Joined Dec 10, '08
From Crescent City
I already checked all fuses. Nothing's wrong with it. Do you guys know where the circut breaker is located at?
post Jun 7, 2012 - 9:41 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (celica_boi @ Jun 7, 2012 - 10:37 PM) *
There is no circuit breaker....everything is a fuse.
post Jun 8, 2012 - 12:03 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Check your alt fuse under the hood again
Those are all the same problems i had when my alt fuse blew
94 st hatch my daily driver
n
post Jun 8, 2012 - 2:19 AM
mindkiller
Joined Apr 6, '12
From somewhere
^^happened to me before 2 i couldn't even move the auto shifter. i remember it was pain in the ass to change it.
post Jun 8, 2012 - 8:07 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
On the passenger side of the radiator, near the botttom and right next to the radiator hose, there is a fan switch screwed into the radiator. It looks like a temperature sensor. Unplug it. If the fans and relays are good the fans will kick on and run nonstop while this wire is unplugged
Lo-Fi Version Time is now: November 30th, 2024 - 4:24 AM
