> jack stands points
post May 7, 2012 - 5:02 PM
mindkiller
Joined Apr 6, '12
From somewhere
for some reason im always confused about where to place the jack stands i just wanna be safe and i dont wanna cause any damage to the car, so i need to know where is the safest and the best spot to place the jack stands(front end)?
post May 7, 2012 - 6:24 PM
trdproven
Joined Aug 2, '05
From Guam
usually hard stable areas. even same places as the jack points. http://www.6gc.net/forums/index.php?showtopic=67709
This post has been edited by trdproven: May 7, 2012 - 6:25 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post May 7, 2012 - 8:14 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (mindkiller @ May 7, 2012 - 5:02 PM) *
Green areas under the rocker panels. suspension crossmember in green.
I wouldnt suggest the red circled crossmember though, I think it would be too unstable....
post May 8, 2012 - 1:23 AM
mindkiller
Joined Apr 6, '12
From somewhere
QUOTE (Special_Edy @ May 7, 2012 - 8:14 PM) *
post May 8, 2012 - 6:12 AM
trdproven
Joined Aug 2, '05
From Guam
the cross member is heavily used by many. in fact its also shown in that diagram.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post May 8, 2012 - 7:20 AM
rave2n
Joined May 29, '09
From Gainesville, FL
I use the side points right under the doors when I use my stands. Depending on what is removed, I'll either place a rim right next to the jack stand as an extra caution, or a jack in another key location. Stand up, shove the car a couple times...if its stable, should stay stable =P
This post has been edited by rave2n: May 8, 2012 - 7:20 AM
post May 8, 2012 - 9:30 AM
Special_Edy
Joined Oct 29, '11
QUOTE (rave2n @ May 8, 2012 - 7:20 AM) *
Oh yeah I left this out.
If you use a jack under the rocker panels( under the doors) you have to make sure you dont lift UNDER the door. Try to put the jack under the door jamb
post May 8, 2012 - 9:52 AM
rave2n
Joined May 29, '09
QUOTE (Special_Edy @ May 8, 2012 - 10:30 AM) *
Yea there are little groves that specify where to jack the car at...hard to miss.
post May 8, 2012 - 10:56 AM
QUOTE (rave2n @ May 8, 2012 - 10:52 AM) *
^This......but it between the obvious jack point notches in the frame seam
post May 8, 2012 - 11:07 AM
Special_Edy
Joined Oct 29, '11
QUOTE (rave2n @ May 8, 2012 - 9:52 AM) *
In response to your post, the jack and jackstand wont both fit under the 'specified' area.
post May 8, 2012 - 11:17 AM
rave2n
Joined May 29, '09
"jack in another key location"
Doesn't exactly say in the same spot now does it?
For us with lowered vechiles, I have to raise my vehicle up enough with the scissors jack at that spot, then I get my other jack out and raise at another point, usually the suspension crossmember. Then I put the stand under it, and find another spot for the jack depending on which side, if not both i'm working on. For safetly, not for the savior of door/panels. I rather wreck the door, then have the car fall on me, even though I'm not even using what you described.
post May 8, 2012 - 11:47 AM
Special_Edy
Joined Oct 29, '11
Lol actually my first post with your post as a quote was an accident. I hit reply next to your post because it was the last one. So I wasnt even talking to you I was talking to the OP. Totally valid point though not to jack directly under the door because you will bend the door jamb if you jack under the threshold plates.
Just like you I will shove my wheel/tire under the door as extra insurance, though 95% of the time Im at my house and use a cinderblock instead. Better to **** up my wheel or car than my face.
This post has been edited by Special_Edy: May 8, 2012 - 12:01 PM
post May 8, 2012 - 1:30 PM
you can put the jack in the rear spot....jack it up and the front comes up enough to sufficiently put a stand in...
stiff chassis ftw...
post May 8, 2012 - 3:06 PM
mindkiller
Joined Apr 6, '12
From somewhere
Thanx everyone for the replay, i wont be able to place the jack stands under the cross member im changing the rear engine mount so i have to remove the cross member, probably would be easier to use ramps but i dont like ramps & im gonna have to buy some eh.
post May 8, 2012 - 3:26 PM
Special_Edy
Joined Oct 29, '11
Place the jack under the suspension crossmember, and the jackstands under the rocker panels. You arent removing the suspension crossmember, just the engine crossmember.
post May 8, 2012 - 5:18 PM
mindkiller
Joined Apr 6, '12
From somewhere
QUOTE (Special_Edy @ May 8, 2012 - 4:26 PM) *
when u say under the rocker panels the inside part or the outside part of the factory jacking points?dose that make any sense?
This post has been edited by mindkiller: May 8, 2012 - 5:20 PM
post May 8, 2012 - 5:49 PM
trdproven
Joined Aug 2, '05
From Guam
good luck with the rear engine mount replacement > hated that one out of the 4. It almost owned.gif me.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post May 8, 2012 - 5:57 PM
mindkiller
Joined Apr 6, '12
From somewhere
QUOTE (trdproven @ May 8, 2012 - 5:49 PM) *
That sucks. do you have any advice regarding the mount job?
post May 8, 2012 - 6:32 PM
rave2n
Joined May 29, '09
QUOTE (mindkiller @ May 8, 2012 - 5:57 PM) *
Well, options follow as.
1. Rock the engine til you can find a way to get it out.
2. Lower the suspension crossmember to gain a small amount of leeway.
3. Scream, kick, jab, slug, freak out, and eventually get it out.
Done it 4 times...I hate it.
post May 8, 2012 - 7:04 PM
mindkiller
Joined Apr 6, '12
From somewhere
QUOTE (rave2n @ May 8, 2012 - 7:32 PM) *
lol..this is me----> Scream, kick, jab, slug, freak out.
Lo-Fi Version Time is now: December 3rd, 2024 - 6:36 AM
