Closed TopicStart new topic
> question about starting( close thread.), question answered
post May 8, 2012 - 1:35 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
alright i know this is a celi forum, but i cant find an answer anywhere else and this place never fails. i have a 96 saturn thats actually not mine, im borrowing it. well the battery died, so i jusmped it and let it run to charge, then i shut it off waited a few minutes and started it to double check. that was last night, today i woke up and wanted to go to the store and it wouldnt start. when i put my key in and turn it all the way the clock shuts off and goes back to factory time when i turn the key off. the battery is less than two years old. can anyone out there help me?
This post has been edited by mneal2_92788: May 8, 2012 - 2:03 PM
post May 8, 2012 - 1:41 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Sounds like loose or corroded battery terminals because you said everything(well the clock at least) shuts off when the key is turned to Start.
You can pour a soda drink onto the battery terminals or use baking soda and water. Pull the clamps off and wire brush them for best results. Now reattach the clamps and make sure theyre nice and tight. Finally, rub some grease over the terminals/clamps to keep them protected from battery acid.
post May 8, 2012 - 1:46 PM
mneal2_92788
Joined Nov 7, '06
QUOTE (Special_Edy @ May 8, 2012 - 2:41 PM) *
im gonna check that out.
post May 8, 2012 - 2:03 PM
mneal2_92788
Joined Nov 7, '06
worked like a charm, thanks man.
Lo-Fi Version Time is now: February 22nd, 2025 - 3:08 AM
