Enthusiast Joined May 8, '12 From Lima Currently Offline Reputation: 0 (0%) ![]() |
Hello everybody,
I have a Toyota Altezza RS200 Z edition, and I am looking for the best way to make it turbo, but I am just considering a 3S solution, maybe making 3SGE turbo, or 3SGTE head onto 3SGE Block, because it would be easier and reliable I guess, so I came to this forum because here are many guys who knows better these engines. Some time ago I’ve heard about this solution. Because of that I’m thinking about buying a 3SGTE 4th generation, part of a Caldina GTT ST215, I’ve heard (because I haven’t seen that engine) one guy here in Peru, made a powerful beams 3SGTE with the following setup. Block (from 3SGE Beams Altezza) Sump (from 3SGE Beams Altezza) Oil pump (from 3SGE Beams Altezza) Flywheel (from 3SGE Beams Altezza) Clutch (from 3SGE Beams Altezza) Manifold + throttle 80 (from 3SGE Beams Altezza) Engine mounts (from 3SGE Beams Altezza) Gearbox (from 3SGE Beams Altezza) Rods (from 3SGTE Caldina GT4 ST246) Pistons (from 3SGTE Caldina GT4 ST246) Crankshaft (from 3SGTE Caldina GT4 ST246) ECU (from 3SGTE Caldina GT4 ST246) Head (from 3SGTE Caldina GT4 ST246) The only difference is the engine, I guess is a little different between ST215’s and ST246’s 3SGTE. Do you know if this project is achievable?. If so, I think making this engine with parts of 3SGE 4th generation and 3SGTE 4th generation would be a little expensive than making my 3SGE turbo. In terms of cost benefit, which option would be the better choice? Does anyone here know about this works? Which would be the better choice with forged internals and some big turbo? I think making turbo my 3SGE with forged internals would not be stronger than a forged 3SGTE, or I can boost the same PSI with the same turbo on both engines? - Any idea about oil squirts in 3SGE? - Any idea about VVT in 3SGE with turbo? I need some experience and comments from other users. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) ![]() |
hmm for more detailed info go here: http://www.mr2.com/forums/beams-owners-group/
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
buy one of the many off the shelf turbo kits?
greddy/trust, HKS, blitz... -------------------- |
Lo-Fi Version | Time is now: February 20th, 2025 - 4:12 PM |
