> belts, power steering, and all the other ones
post May 9, 2012 - 9:41 AM
94odiecelica
Joined Jan 24, '12
From titusville pa
i was wondering if anyone had a link or could just tell me, is the tensioner under the alternator in a st the tensioner for all the belts? i have the 3s-fe and wanted to replace all the belts. i know the waterpump and alternator belt use the alternator tensionor, but i wasnt sure if that would loosen the other two to replace, or if there was another tensioner for the power steering one
Replies (1 - 6)
post May 9, 2012 - 9:43 AM
KAOS
Joined Apr 18, '06
From Calgary, Canada
The power steering assembly is the tensioner for the power steering pump. You have to loosen it from underneath the car.
Easier to remove the wheel first, then you should be able to see better too.
post May 9, 2012 - 10:22 AM
94odiecelica
Joined Jan 24, '12
From titusville pa
QUOTE (KAOS @ May 9, 2012 - 9:43 AM) *
im still new to workin on cars, so im trying to learn all i can, but where is the pwer steering assembly? like is it right under the belt, so i can get to it easily with the tire off? and will it be like the tensionor for the alternator?
post May 9, 2012 - 10:29 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
If youre looking in the passenger wheel well it is to the left of the crankshaft pulley. You have to loosen the center bolt, I think its a 17mm or 19mm. Then you have loosen the tensioner bolt
This post has been edited by Special_Edy: May 9, 2012 - 10:34 AM
post May 9, 2012 - 4:10 PM
94odiecelica
Joined Jan 24, '12
From titusville pa
do you know what the last one is? power steering, alt. and water pump. those are the two i know. ande how would you change the third one?
post May 9, 2012 - 5:10 PM
KAOS
Joined Apr 18, '06
post May 9, 2012 - 7:41 PM
mandrek
Joined May 4, '05
From western MD/NOVA
on the ST there are 3 belts...
main goes around crank, alt, water pump.
2nd goes around water pump and power steering
3rd goes around crank, tensioner and A/C compressor.
oh and the tensioner under the alt is the tensioner for the A/C belt.
Lo-Fi Version Time is now: January 11th, 2026 - 9:02 PM
