12 Pages V  « < 5 6 7 8 9 > »
> [5S-FE] Syaoran's Build, Update August 14!
post Mar 26, 2013 - 2:54 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (ricochet1490 @ Mar 26, 2013 - 1:24 PM) *
Sounds like a good time. Upping the compression?
Just a tad. Not of a concern since I'm not upping the boost that much on the stock head. Pretty much diminishing returns.
QUOTE (Smaay @ Mar 26, 2013 - 1:54 PM) *
why didnt you just contact ATS racing and get a crankshaft from them and use yours as a core? grinding down the 5S crank is perfectly fine, i even have one in my All-Trac
Just the shipping of it would've been killer, plus I'd have to wait over 2 weeks between shipments. (I'm in Puerto Rico) It would've probably been as much if not more than $560 when all is said and done.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Mar 28, 2013 - 5:24 PM
Syaoran
Joined Jan 4, '12
From US
So now I'm on the hunt for somebody who can TIG weld or somebody who MIGs and think he can pull off what I want. I want a custom downpipe for my turbo, v-band on the exhaust, and v-band on the wastegate. The trick is that I want a v-band flange on the downpipe flange, like so:
And a tube going over the vband flange like so:
However the tube would be with a v-band at the end, and not a 2-bolt clamp like pictured.
This post has been edited by Syaoran: Mar 28, 2013 - 5:24 PM
post Mar 28, 2013 - 5:27 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
search around your area for a reputable automotive fabrication shop
エキサイティングカーレーシングチーム!
post Mar 28, 2013 - 6:01 PM
Syaoran
Joined Jan 4, '12
From US
I'm in that process.
post Mar 31, 2013 - 9:12 AM
looking at your pics more, and understanding better what you want now, i could definetly do this for ya, that tricky part is getting the wastegate pipe located exactly where you want it.
post Mar 31, 2013 - 2:45 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (presure2 @ Mar 31, 2013 - 10:12 AM) *
Well it doesn't need to be EXACTLY there, it's just that I think that's the most comfortable place for the 5S configuration on the celica, since the alternator is right next to the downpipe (i'm going to put the turbine towards the passenger side and the compressor towards the driver side)
This post has been edited by Syaoran: Mar 31, 2013 - 2:45 PM
post Apr 5, 2013 - 1:43 AM
Syaoran
Joined Jan 4, '12
From US
Well I got the head back today, will be getting the block back tomorrow from a bore, hone, deck, cleaning, replacing the freeze plugs and paint.
I checked at my local Toyota autoparts and the complete gasket set price is $219, does that sound right? (I know it's in the ballpark of ~200)
post Apr 7, 2013 - 12:28 PM
Syaoran
Joined Jan 4, '12
From US
Update:
Waiting on the rods, to arrive to start assembling the short block. Gotta buy a gasket set and both pumps, and ARP studs to have it all assembled
post Apr 10, 2013 - 12:16 AM
Syaoran
Joined Jan 4, '12
From US
Update time:
TRD Rears
New H-Beams besides the 5S (left) and 3S (right) stock rods.
Awesome hardware on these
Up against 5S rod bolts (not a formidable opponent)
Up against 3S rod bolts (a much more formidable opponent)
And finally, my new v-band 38mm wastegate. Basically an outright copy of a Tial MV-S (I've had them side by side, and the differences lie only on the outside, visually speaking)
post Apr 12, 2013 - 11:05 PM
Syaoran
Joined Jan 4, '12
From US
A mock up...
post Apr 14, 2013 - 12:48 PM
richee3
Joined Jun 29, '08
From Denver
So is this still a student-budget build? If so, you have the biggest budget of any student I've ever seen. laugh.gif I can't wait to see it all come together, and especially see some dyno numbers. smile.gif
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Apr 14, 2013 - 7:57 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (richee3 @ Apr 14, 2013 - 1:48 PM) *
Yeah, I'd consider this a budget build with mid-grade parts, not ghetto-rigging anything nor going with $1250 turbo manifold that could probably serve as good a purpose as my $169 one tongue.gif
post Apr 16, 2013 - 7:23 PM
Syaoran
Joined Jan 4, '12
From US
post Apr 16, 2013 - 8:15 PM
ricochet1490
Joined May 3, '11
From Ohio
what is it?
post Apr 16, 2013 - 8:20 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
ooh! guessing game!
um
um
3SGE throttle body!
EDIT:
I was wrong.... lolol
This post has been edited by Tigawoods: Apr 16, 2013 - 8:30 PM
エキサイティングカーレーシングチーム!
post Apr 16, 2013 - 9:05 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (ricochet1490 @ Apr 16, 2013 - 9:15 PM) *
what is it?
Left is 98+ camry TB (same as ours, jus different TPS and bolt pattern), right is my TB after wasting $121 dollars on it lol
QUOTE (Tigawoods @ Apr 16, 2013 - 9:20 PM) *
ooh! guessing game!
um
um
3SGE throttle body!
EDIT:
Yeah xD
post Apr 18, 2013 - 4:58 PM
Syaoran
Joined Jan 4, '12
From US
What I'll be using:
Studs installed in the block, tightened down all the way with an allen key and then loosened half a turn. I still have grind down the two below the scissor gears on the head.
post Apr 20, 2013 - 1:46 AM
Syaoran
Joined Jan 4, '12
From US
And on the topic of turbos... just a teaser:
post Apr 20, 2013 - 10:27 PM
Syaoran
Joined Jan 4, '12
From US
Plastigauged the main caps, they all came out pretty good:
Main#1
Slightly less than 0.038mm
Main#2
Slightly less than 0.038mm closer to 0.025mm
Main#3
Main#4
Main#5
Meanwhile... on another side of the world:
This post has been edited by Syaoran: Apr 20, 2013 - 10:28 PM
post Apr 21, 2013 - 1:31 PM
ricochet1490
Joined May 3, '11
From Ohio
Looks like you have some quality part s going on here!
Lo-Fi Version Time is now: February 17th, 2025 - 3:49 AM
