12 Pages V  « < 8 9 10 11 12 >
> [5S-FE] Syaoran's Build, Update August 14!
post Sep 15, 2013 - 10:08 PM
Syaoran
Joined Jan 4, '12
From US
Soon. Can't say exactly when.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Sep 19, 2013 - 10:26 AM
Syaoran
Joined Jan 4, '12
From US
I put in a spacer in the front to see how 20mm looks. I like it. Needs more spacing in the rear though.
Side angle:
Side:
Front quarter:
Rear quarter: (wheel is slightly turned to the left)
I also installed my two extra gauges finally. Took power from the 12V cig lighter, ground at the block, vacuum at the IM (gonna have to get a vacuum manifold by the looks of it).
Prosport amber/white 52mm performance gauges. Electric Oil Pressure and Mechanical Boost:
Video: http://s269.photobucket.com/user/arolbreak...857b68.mp4.html
There's also an Innovate MTX-L wideband gauge next to them which is connected to the Megasquirt for datalogging and EGO correction purposes.
post Sep 19, 2013 - 11:54 AM
kevin311
Joined Dec 23, '12
From North Carolina
How ironic I was just browsing through spacers yesterday and wondered what would get the celica lookin right. Looks good. Nice gauges too, nice addition. Keep it coming man
post Sep 19, 2013 - 1:15 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (kevin311 @ Sep 19, 2013 - 12:54 PM) *
Thanks, while that all depends on your drop, wheel and tire size..
my setup consists of tein springs, 195/60/15 tires on 15x6.5 7th gen GT wheels.
20mm front, 20mm rear and I think I'm going to get 30mm for the rear because it still has a lot of space.
post Sep 19, 2013 - 7:58 PM
kevin311
Joined Dec 23, '12
From North Carolina
How much lower are you sitting with the Teins?
post Sep 19, 2013 - 10:28 PM
6strngs
Joined May 12, '06
From Wilmington, NC
subscribing...
post Sep 20, 2013 - 12:17 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (kevin311 @ Sep 19, 2013 - 8:58 PM) *
Not sure since I've never had stock height. PO decided it was a good idea to cut the springs. I put on the teins a little after I got the car.
post Sep 20, 2013 - 4:34 AM
kevin311
Joined Dec 23, '12
From North Carolina
Oh ok. Yeah never understood why people cut the springs. I'd be afraid something would screw up bc of that. Car looks good dude. Gonna stay with the 15" rims or eventually go bigger?
post Sep 20, 2013 - 10:26 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (kevin311 @ Sep 20, 2013 - 5:34 AM) *
Gonna stay 15" for now, cheaper tires and a more comfortable ride
post Oct 5, 2013 - 1:20 PM
Syaoran
Joined Jan 4, '12
From US
Boosted. Clutch slips. Update coming soon.
post Oct 5, 2013 - 1:41 PM
kevin311
Joined Dec 23, '12
From North Carolina
Hell yes! What's your first impression?
post Oct 5, 2013 - 2:13 PM
Box
Joined Feb 23, '12
From Warrior, AL
DYNO SLIPS!!!
2001 Miata LS 5-speed
post Oct 5, 2013 - 4:32 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (kevin311 @ Oct 5, 2013 - 2:41 PM) *
Feels nice, aside from the horribly bad slipping clutch.
QUOTE (Box @ Oct 5, 2013 - 3:13 PM) *
DYNO SLIPS!!!
Not gonna waste cash for a 6psi dyno on a bad clutch haha, they will come soon.
post Oct 5, 2013 - 4:34 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Oct 5, 2013 - 4:42 PM
Syaoran
Joined Jan 4, '12
From US
Oh definitely
The FMIC ended up fitting almost how I wanted it to. I might re-do one bend so that both sides are showing the pipes. Pics of what I mean coming soon.
post Oct 5, 2013 - 8:15 PM
Looks real nice with the spacers, I regret not jumping on a pair. What do those alloys weigh? Mine are the same size, 17.5lb.
post Oct 5, 2013 - 9:16 PM
Syaoran
Joined Jan 4, '12
From US
Haven't weighted them, but they are definitely much lighter than the previous 17's that were on there. The change in acceleration when N/A definitely dictated so.
I think they're the usual 15's, I'd say around 16-17lbs is about right. MAYBE a little less, because most people who get these wheels around here is due to their light weight, apparently.
Here's some pics for you guys:
Thinking about slightly changing the piping on the left side so that instead of a coupler you can see a pipe, because I'm kinda OCD like that.
post Oct 5, 2013 - 9:21 PM
Box
Joined Feb 23, '12
From Warrior, AL
Don't feel bad, I'm the same way.
post Oct 6, 2013 - 9:44 AM
6strngs
Joined May 12, '06
From Wilmington, NC
Looks like your oil filter was able to fit without a relocation kit? I'm wondering if it might get too hot being that close to the downpipe though?
post Oct 6, 2013 - 7:49 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (Box @ Oct 5, 2013 - 10:21 PM) *
I don't like it. Even my sister in law told me to change it haha.
QUOTE (6strngs @ Oct 6, 2013 - 10:44 AM) *
It fits. Depending with what eyes you look at it with, the only downside (maybe upside because I'm forced to use a quality filter) to it is that the ONLY filter than will fit is the OEM toyota one. The other filters I've found have a protruding thread and therefore don't fit between the oil cooler and the wastegate port tube, but that's only in my case. My recommendation is that you get a manifold properly fabbed to not need to have a custom wastegate flange fabbed up that will take up almost all of the space.
Found that out the hard way. I drained the oil and I'm stuck without no filter. Will have to get one tomorrow kindasad.gif
Lo-Fi Version Time is now: November 23rd, 2024 - 8:31 AM
