> Vacuum Leak Question, A bit stumped here
post May 10, 2012 - 11:43 AM
bsamps4
Joined May 16, '10
From Raleigh
My car only runs around -19 vacuum when at idle. I have changed from the stock bov to a synchronic bov in hopes that I just had a worn out factory blow off valve, but there is no change in vacuum...my idle improved slightly (but i think this might be due to the synchronic valve in the open position at idle) I have checked and checked and checked for a vacuum leak and have yet to find one. I've replaced several lines, sprayed everything down with starter fluid, re-checked all of my boost clamps etc....Is there something i'm missing here? It seems like I should be able to locate this issue no problem. The car boosts great, but I'm just worried that i've missed something. Are there any common fail points that I should re-check?
Note: both blow off valves are making the same noise. After looking at youtube it would seem that it should just be ONE pssshhh. Mine sounds like psssshpssshhhpssshhh.
post May 10, 2012 - 3:42 PM
every car varys a bit.
the BGB says -18 - -22hg is normal, so unless your noticing other problems, i wouldnt worry about it.
jenns car starts ~ -16 - -18hg cold, then makes a bit more warm ~20 or so.
what kind of gauge you using? and how accurate is it?
post May 10, 2012 - 6:49 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
youre fine ben, 19-20 is normal, my first swap ran 19 vac. using an auto meter boost gauge. right now, mine on the other hand is reading 15-16 for some strange reason... rolleyes.gif
post May 10, 2012 - 7:10 PM
bsamps4
Joined May 16, '10
From Raleigh
Its an auto meter I can't imagine its very accurate. Defi is a bit out of my price range.
post May 10, 2012 - 7:25 PM
texasnick
Joined Feb 23, '10
From Vancouver, BC
Altitude also plays a factor in idle vacuum.
In Calgary (elev. approx. 1,000 m) my car idled at around 16 in when warmed up.
In Vancouver (sea level) I consistently get around 19-20.
Lo-Fi Version Time is now: February 13th, 2025 - 2:56 PM
