open and closed loop, at what point do they shift from each other? |
May 10, 2012 - 12:04 PM |
Enthusiast Joined Sep 22, '10 From pomona, ca Currently Offline Reputation: 1 (100%) |
title says it all, any one know when the car (94 gt, 5spd) is in closed loop and open loop? sorry for the noob question, not really a noob i just dont know... lol
i know some cars change between throttle percentages, others by temperature, etc.... how does the closed loop and open loop work on our cars? |
May 10, 2012 - 12:17 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Noob Question?
I don't even know what closed loop and open loop are haha. When it comes to cars at least. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
May 10, 2012 - 12:32 PM |
Open loop is when the ECU is running on a base map before the engine warms up. Closed loop is when the engine has warmed up and starts relying on input from all the various sensors. That's how it is on the BEAMS, anyway. The 5S could be different.
This post has been edited by richee3: May 10, 2012 - 12:33 PM -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
May 10, 2012 - 3:45 PM |
i tried to answer this as best i could in the PM i replied to, but richee has the basic idea, it also goes into open loop @ WOT, and i also believe that it uses open loop from around 70% throttle and a certain RPM, ect.
13.6@108MPH, 5SFTE Powered |
May 10, 2012 - 6:22 PM |
Google Control Theory to learn more about it, but the basic idea is that closed loop takes into account input signals while open loop does not.
Here http://en.wikipedia.org/wiki/Control_theory -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 22, 2012 - 10:53 AM |
I just wanted to know because my ecu was fighting my safc2 in closed loop tuning. I got around this issue by simply disconnecting my O2 sensor (force open loop). So far so good, my safc2 is working nicely in low and high map. No more jumpy afr in low map. Now I can tune my low and partial throttle afr to wat I want. Just wanted to share that info...and thanks for all the replies
One more thing: im not responsible if sumthing happens to your car if u try wat I did, do it at your own risk lol |
Lo-Fi Version | Time is now: January 10th, 2025 - 3:26 PM |
