> Manual Transaxles that fit 7A-FE
post May 10, 2012 - 11:36 PM
dcolby10
Joined May 10, '12
From Mesa, Arizona
Hey
I know that this has probably been answered already in another post, however I couldn't find it anywhere. I am wondering what transmissions fit the 7A-FE engine that resides in my Celica. I know that the tranny that is bolted onto it right now is the C52, but I was wondering what other transmissions fit and if it would be better just to rebuild the one that I currently have.
Thanks
This post has been edited by dcolby10: May 10, 2012 - 11:37 PM
post May 11, 2012 - 10:04 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
the 5 and 6 speed in the 7th gen celicas are very close. you might have to drill a hole or two.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 11, 2012 - 10:41 AM
dcolby10
Joined May 10, '12
From Mesa, Arizona
Excellent, thank you very much
post May 11, 2012 - 8:26 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Any C series trans that originally came on an A Series engine. The 7th gens' don't fit... the bellhousings are different. That leaves you with... a TON of options from gear ratios to final drives, to LSD and even between 5 speed and 6 speed... given that the C series trans are probably toyota's most common.
http://en.wikipedia.org/wiki/List_of_Toyot...ssions#C-series
post May 12, 2012 - 5:15 AM
dcolby10
Joined May 10, '12
From Mesa, Arizona
I found a 1998 Corolla transmission that I figure is a C59 series that my mechanic is going to strip the gears out of and place into my C52. Hopefully this will work, or else I will have to pay to get brand new gears which on a student budget is quite expensive. By the way thanks Kwanza for the reply.
Lo-Fi Version Time is now: November 22nd, 2024 - 8:07 PM
