ok offset ? |
ok offset ? |
May 11, 2012 - 12:28 AM |
Enthusiast Joined Feb 2, '12 From los fresnos, tx Currently Offline Reputation: 0 (0%) |
Im soon to get my XXR's 527 Wheels, with 17x9.75 with 25 offset. I measured it with a friend he said they fit just fine, any opinions or comments regarding this measurents ? plz let me know THNX
May 11, 2012 - 1:15 AM |
its pretty aggressive, i would assume with the right negative camber youd fit it under with rolled fenders. Dunno if you need to pull but i would assume you would have negative camber decently. I know of a 7th gen with the same set and spec and its cambered pretty good with natural camber. a roll or cut of the fender if its lowered is a must.
This post has been edited by trdproven: May 11, 2012 - 1:17 AM -------------------- 94 Celica GT
May 11, 2012 - 1:50 AM |
Enthusiast Joined May 4, '09 From coral springs florida US Currently Offline Reputation: 21 (100%) |
The front ones will stick out a LOT! And you cant slammed if you are planning to.
My cat is pretty low and i tested 18x9.5 +35 with 225/40s and the front ones sticked out of the fender and the tires were rubing the fenders bad. 18x9.75 +22 are going to.stick even more.. i would not get them if you are going to lower the car. Try 18x9.5+40 for the front and +25 rear (using a 15mm spacers) This post has been edited by diegohiga: May 11, 2012 - 2:18 AM -------------------- |
Lo-Fi Version | Time is now: November 27th, 2024 - 10:19 AM |
