Closed TopicStart new topic
> full 1995 toyota celica 7afe dohc 1.8l engine gasket set stock, for sale
post May 11, 2012 - 1:10 AM
dnewton
Joined Mar 6, '11
From Canoga Park
head gasket engine set all the gaskets needed for doing a big repair like a head gasket job for 1995 toyota celica 1.8l 7afe dohc engine $60.00 obo
still new in the packaging unopened
David 818 272 6430 Canoga park,ca 91306 west San Fernando valley area
This post has been edited by dnewton: May 11, 2012 - 1:11 AM
post May 11, 2012 - 1:13 AM
dnewton
Joined Mar 6, '11
From Canoga Park
QUOTE (dnewton @ May 11, 2012 - 2:10 AM) *
still new in the packaging unopened will work on all celicas with the 7afe engine 1994,1995,1996,1997 years I think just check ur under the hood catalyst info sticker to check.
post Oct 7, 2014 - 6:16 AM
finalate
Joined Aug 16, '11
From california
When did the 7afe go dohc?
post Oct 7, 2014 - 9:47 AM
msk59
Joined May 10, '14
From Tulsa, OK
I have a 1996 and it is DOHC.
post Oct 7, 2014 - 9:53 AM
finalate
Joined Aug 16, '11
From california
QUOTE (msk59 @ Oct 7, 2014 - 9:47 AM) *
No wayy wtf?!? And they say the 7afe wasnt made for performance ... Well **** , I feel like I'm totally missing out w my sohc 7afe st. I send need to find one and turbo that bitch! This changes everything
post Oct 12, 2014 - 10:26 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (finalate @ Oct 7, 2014 - 9:53 AM) *
All 7afe s are DOHC, there's one master can gear driven by the belt and then under the valve cover theyre connected.
I might not be using the correct terminology but they are ALL DOHC to my best knowledge.
post Oct 12, 2014 - 10:54 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
QUOTE (Malhar95 @ Oct 12, 2014 - 9:26 PM) *
They're definitely all DOHC. Just one master cam that one can see from the outside of the motor connected to the other cam under the valve cover.
June '12 COTM
'95 AT200
post Oct 13, 2014 - 3:20 AM
igpx12
Joined Jan 30, '14
From Cortland NY
It is a DOHC motor but 7A employed a "slave cam system", the camshafts being geared together and driven off one camshaft's sprocket unlike say the 4A-GE both camshaft sprockets are rotated by the timing belt. The reason why some might view the 7A as a SOHC is that it only uses a single cam to run both. However as far as performance, adjustments in timing your intake and exhaust valves are far easier with a twincam setup as you can use the cam gears to adjust with without having to tear down the head of the engine. Sorry dnewton for using your FS thread to explain this, best of luck on the sale, I'd take it but not on the lookout for an engine rebuild just yet.
This post has been edited by igpx12: Oct 13, 2014 - 3:22 AM
1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool.
Lo-Fi Version Time is now: December 2nd, 2024 - 2:53 AM
