> Firing order, 1997 Celica GT
post May 11, 2012 - 10:55 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Okay. So I ran a CEL reader and it says my car is misfiring? When the car is running okay? The idling is not rough but it boggles a bit but nothing major. I'm thinking it's idling like that because of dirty TB. What I have my spark plug firing order set up is;
FACING THE ENGINE Cylinders: 1 - 2 - 3 - 4
FACING THE DISTRIBUTOR CLOCK WISE: 1 - 2 - 4 -3
COUNTER CLOCKWISE: 1 - 3 - 4 - 2
Can someone let me know if I have the correct firing order? I just want to double check. I searched online and they all said 1 - 3 - 4 - 2. I'm pretty sure how you read it is starting from the bottom left of the distributor going counter clockwise. Right? That's how I read it.
This post has been edited by ILoveMySilly97: May 11, 2012 - 11:33 PM
post May 12, 2012 - 1:59 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
The distributor is located on the back side of the engine, so it spins the opposite direction of the crankshaft. Firing order is 1342 and the eninge rotates clockwise from the front, but it rotates 1243 clockwise or 1342 counterclockwise on the distributor.
post May 12, 2012 - 10:01 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Special_Edy @ May 12, 2012 - 2:59 AM) *
Yea. So I did have the correct firing order. Might be a loose plug or wire then.
post May 12, 2012 - 9:07 PM
zfjohnson07
Joined Apr 11, '09
you need to search search search!!! i was new once, heard the same stuff, there is a chat on fb you can talk to ppl or post stuff to get faster answers also
post May 15, 2012 - 1:52 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (zfjohnson07 @ May 12, 2012 - 9:07 PM) *
Yea I went on AutoZone and they had the perfect diagram for it.
This post has been edited by ILoveMySilly97: Apr 19, 2013 - 12:28 AM
post May 15, 2012 - 6:20 PM
As you can see from that diagram, you dont need to know the firing order. You just need to match up the numbers on the distributor with cylinders 1,2,3,4 from left to right. If you match up the plug wire that says 3 to the second cylinder, you will have problems.
Lo-Fi Version Time is now: December 1st, 2024 - 9:24 PM
