Distributor Upgrade?, Trigger wheel... |
May 14, 2012 - 9:04 AM |
Hey guys,
I'm looking for a Distributor that fits in the FE head that's better than our stock ones. I need one with at least a 24-1 wheel. I'm using an EMS so it doesn't matter if it's got a coil in it or not (MS-II has an igniter in it, so something like an MSD coil can be used) I just need something that fits our head. Maybe pre-rev2 distros? I think they had a 24-1 trigger wheel in them. -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
May 14, 2012 - 1:56 PM |
Enthusiast Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
How is one Distributor better than another?
-------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
May 14, 2012 - 10:32 PM |
How is one Distributor better than another? It's only better because I'm using an EMS... but technically a distributor with a trigger wheel with more teeth is better because it is more precise. It's all a matter of whether or not you've got an ECU that can take advantage of that. Mine seems to be 4-1, and I see that there are some 5s-fe distributors that are 24-1 but they seem to be external coil distributors. That's no issue for me, the issue is that I can't find which nor where are the distributors with the 24-1 trigger wheel... -------------------- 1993 Celica GT Coupe - sold
May 14, 2012 - 10:42 PM |
Look into 5th gen celicas they have (atleast some) a exturnal coil dist on them
hope that helps narrow down your search -------------------- 95 gt coupe, v6 swap weekend toy
May 15, 2012 - 12:10 AM |
which FE head, both the 5S and 7A are FE heads
May 15, 2012 - 12:44 AM |
which FE head, both the 5S and 7A are FE heads I own a GT, as my sig says. Sorry I didn't specify it in the post. -------------------- 1993 Celica GT Coupe - sold
May 15, 2012 - 12:46 AM |
If you are going with Megasquirt then you will have a hard time getting any Toyota distributor to function correctly, at least from what I have read when I looked into this.
Your best bet is to convert to the external trigger wheel with ford coil packs. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 15, 2012 - 8:37 AM |
If you are going with Megasquirt then you will have a hard time getting any Toyota distributor to function correctly, at least from what I have read when I looked into this. Your best bet is to convert to the external trigger wheel with ford coil packs. I've noticed that... We're thinking about going 36-1 on the crank pulley. Just need to find the right machine shop who'll do it without messing stuff up. -------------------- 1993 Celica GT Coupe - sold
Lo-Fi Version | Time is now: November 29th, 2024 - 5:46 PM |
