At200 & st202 brake system, Are they the same? |
May 16, 2012 - 10:58 PM |
Enthusiast Joined Mar 13, '06 Currently Offline Reputation: 2 (100%) |
Hi,
I'm just wondering if anyone know if the AT200 brake kit system is the same as for ST202 brake system. I was looking at the 13" brake system for the ST202 & don't know if it would fit. Any Ideas..... Thanks |
May 16, 2012 - 11:06 PM |
I know the ST has drums on the rear, where the GT has discs. Also the front brakes are bigger on the GT.
May 17, 2012 - 12:00 AM |
Enthusiast Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
The AT200 has a bigger ebrake. lol
-------------------- JDM guy made me do it.
May 17, 2012 - 1:48 AM |
The AT200 has a bigger ebrake. lol ^^ says the man who takes pics of his car on a hill leading down straight into a lake!! -------------------- Group buy to replicate Narrow E series transaxle parts
May 17, 2012 - 8:44 AM |
The at200 front calipers and rotor are smaller then the ST202.
I tried to swap them out when I found a stripped bolt on the bracket that holds the caliper onto the hub. No dice, they are certainly different sizes. |
May 17, 2012 - 11:56 AM |
Enthusiast Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
The GT has:
_ Larger Front Discs Brakes (Caliper / Rotor / Pad / Brake Line) _ Rear Disc Brakes (Caliper / Rotor / Pad / Brake Line) _ Different Bias Valve Most of my research has indicated that the rest of the brake system is identical between the models (AT200 / ST204) -------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
May 17, 2012 - 5:59 PM |
The AT200 has a bigger ebrake. lol ^^ says the man who takes pics of his car on a hill leading down straight into a lake!! Ha ha, I carry a chock block in my pocket it also helps with the ladies -------------------- JDM guy made me do it.
May 17, 2012 - 6:54 PM |
The GT has: _ Larger Front Discs Brakes (Caliper / Rotor / Pad / Brake Line) _ Rear Disc Brakes (Caliper / Rotor / Pad / Brake Line) _ Different Bias Valve Most of my research has indicated that the rest of the brake system is identical between the models (AT200 / ST204) ya what he said!!!^^^^^^ -------------------- Group buy to replicate Narrow E series transaxle parts
Lo-Fi Version | Time is now: November 27th, 2024 - 9:28 AM |
