5S-FE Aftermarket Header Install |
May 17, 2012 - 9:09 PM |
Enthusiast Joined Mar 1, '12 From New York Currently Offline Reputation: 0 (0%) |
Are there any stickies of how to install a header on a 5S-FE. All I can find is one for 7A-FE. I know that there is a difference in the amount of O2 sensors, but do I need an extension from the bottom of the header to the cat? Or does the ebay aftermarket header fit perfectly into place.
May 17, 2012 - 9:20 PM |
If you get the "Ebay" header (every brand is basically the same) it is just bolt on. No need to extend anything, it will have a spot for both o2 sensors, you will probably need to replace the lower one because it's usually impossible to get out of the stock header.
May 17, 2012 - 10:56 PM |
Alright, so the bottom O2 sensor usually is a pain, will keep that in mind. Is there any sort of silicone that should be put on the gaskets so that there is no chance of leaks?
May 17, 2012 - 11:14 PM |
ive put 10,000 mile on mine with no leaks an all i did was take it out of the box an put it on
no extra stuff on the gaskets or anything -------------------- 95 gt coupe, v6 swap weekend toy
May 17, 2012 - 11:41 PM |
alright but there has to be some sort of silicone for the inner seal from the bottom of the header into the exhaust. That ring like seal correct?
May 18, 2012 - 12:12 AM |
May 30, 2012 - 10:54 AM |
Enthusiast Joined Jun 5, '07 From Santa Maria Currently Offline Reputation: 1 (100%) |
Alright, so the bottom O2 sensor usually is a pain, will keep that in mind. Is there any sort of silicone that should be put on the gaskets so that there is no chance of leaks? Get an O2 sensor socket (rent from autozone) and a breaker bar. It is a pain to get out but having the right tool makes it sooo much easier. -------------------- |
Lo-Fi Version | Time is now: November 27th, 2024 - 7:06 AM |
