> Help taking out primary amp
post May 19, 2012 - 11:15 AM
Xerazal
Joined Apr 27, '12
From Virginia, USA
I need help taking out the primary amp from my 1994 celica GT. I tried just taking it out after taking out the ac unit and head unit but the bolt is melted on.. Any instructions on how to take this thing out?
post May 19, 2012 - 11:37 AM
you have to take out the entire plsatic surround that covers the shifter, to make easier access to remove all botls
post May 19, 2012 - 6:46 PM
Xerazal
Joined Apr 27, '12
From Virginia, USA
QUOTE (njccmd2002 @ May 19, 2012 - 11:37 AM) *
How do you do that? I've been trying to for a few hours and couldn't figure it out
post May 19, 2012 - 7:57 PM
hmm
itty bitty complicated...
you car needs to look like this....
held by several screws, and need to wiggle it between the glove box, and the under the steering wheel cover.
may need to remove seats to access the screws.
only held by a total of 4 orr 6 screws
post May 20, 2012 - 1:21 AM
Xerazal
Joined Apr 27, '12
From Virginia, USA
QUOTE (njccmd2002 @ May 19, 2012 - 7:57 PM) *
hmm
You're kidding right.. I have to take all that out just to get to the amp? Damn I might as well keep trying to take the bolt off through the hole that the ac unit and radio sit in..
post May 20, 2012 - 2:34 AM
azian_advanced
Joined Apr 18, '05
From Calgary
trust me it's a lot easier to remove that surround.. i've replaced my amp before.
but you don't need to remove the seats like in that picture
post May 20, 2012 - 7:31 PM
no, but a good chance to vacuum...
the screws are blocked by the seats, but a good 10mm wrench can help.
but yes its easy, and you will find quarters, pennies, joints, pencils, bugs, etc.
post May 23, 2012 - 9:25 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
I used a racheting 10mm wrench to remove the nuts/bts without pulling the entire dash out just the radio and shifter trim.
You can get two of the bolts/nuts from above but the passenger side one on the floorboard has to be gotten with a 10mm between the dash and carpet on the pass. side footwell
This post has been edited by Special_Edy: May 23, 2012 - 9:27 AM
Lo-Fi Version Time is now: February 22nd, 2025 - 10:05 AM
