> E153 in my 6th gen
post May 21, 2012 - 1:58 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
ok so you saw my V6 swap with E153, im using the stock GT front mount and ST205 rear mount. the drivers side mount is what im having an issue with. the stock S54 bracket that bolts on the bell housing does not bolt to the E153. the bolt pattern is different. what im using now is an ST185 mount that i had from my All-Trac swap. i had to grind some material off the sides to get it to fit.
Anyways, why are there claims that the stock mount will work on the E153?
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 21, 2012 - 2:05 PM
mkernz22
Joined May 10, '10
From MA
I always thought it was the st205 mount that worked with the E153
post May 21, 2012 - 4:56 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Stock st205 mounts work if you use all 3 of them
Thats what stephen-lee did with his 3vz/e153
94 st hatch my daily driver
n
post May 22, 2012 - 10:47 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
i didnt get any mounts, i had to find the rear used, and i used my ST185 drivers side. its working now but i thought that the GT mount could be used, guess not.
post May 22, 2012 - 10:54 AM
czwalga
Joined Sep 27, '10
From pittsburgh
It's only slightly different, you can cut it a little bit and get two of the bolts to line up. I made mine work with my e154f.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post May 23, 2012 - 3:11 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
actually used a gt drivers mount..
had to flip the lower bracket and cut off a section of the gt isolator
the ST205 drivers mount should be bolt on if you get it as the e53, e153, and e154f (the awd box) uses the same transmission case.
post May 23, 2012 - 8:35 PM
placham
Joined Nov 24, '10
From Worth, IL
St205 rear mount and bracket, st205 top driver side bracket and USDM GT St204 mount, St204 USDM GT front bracket and mount.
Driver side bracket looks like casted webbing, not stamped steel bracket, think you can get this off of old Celica like 88 with S54 trans, would be something like st164 or something, or go on GT4OC.net and buy it from one of the breakers doing St205 part out, or try ebay.co.uk British version.
Matt.
Oh yeah driver side mount should be same on ST204 GT and St205 its the bracket thats different attaches differently to trans, cause I dont remember buying the mount.
This post has been edited by placham: May 23, 2012 - 8:37 PM
Lo-Fi Version Time is now: January 10th, 2025 - 11:21 AM
