Squeaking clutch noice |
May 21, 2012 - 6:28 PM |
Enthusiast Joined May 21, '12 From Stockholm Sweden Currently Offline Reputation: 0 (0%) |
For years I have had this squeaking when i press the clutch, it sounds like it come from the engine bay rather than the pedals.
Now after the ST205 been in the garage for a year its worse than ever, people on the street turn around if I press the clutch at a stoplight.. It does not sound like a mechanic (as in metal to metal) sound, its more like a uhm, cheap kid whistle. Any ideas ? I was thinking of changing the clutch fluid as the first thing, but it looked like it was a PITA to do ..I can add that the clutch works as good as ever -------------------- Black Toyota Celica GT-Four ST205 1996 (My love..)
Silver Toyota Celica GT ST202 1994 (Used to be my daily driver) Black SAAB 9-5 Aero sportcombi 2005 (My daily driver..) Black Suzuki GSX1100e 1983 (My steam locomotive) |
May 21, 2012 - 6:48 PM |
I get a squeaking sound with mine every once in a while. It goes on and off. I think it might be the TOB pushing against the pressure plate or the slave cylinder moving the fork
May 21, 2012 - 7:12 PM |
Enthusiast Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) |
most likely the clutch release fork where it pivots inside the transmission or the slave cylinder rod that presses on the release fork.
-------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
May 21, 2012 - 11:02 PM |
Most likely the slave cylinder...
-------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
May 22, 2012 - 2:45 AM |
It just feels strange if it is the slave cylinder that sounds like that when it have been working for years with this sound.
..I haven't looked but I guess that its impossible to change the slave cylinder without removing the transmission on those cars, which means that there is no way in h**l I would do it until it stop working completly If it is friction between metal parts well, hard to do anything about that too from the outside -------------------- Black Toyota Celica GT-Four ST205 1996 (My love..)
May 22, 2012 - 10:52 AM |
It just feels strange if it is the slave cylinder that sounds like that when it have been working for years with this sound. ..I haven't looked but I guess that its impossible to change the slave cylinder without removing the transmission on those cars, which means that there is no way in h**l I would do it until it stop working completly If it is friction between metal parts well, hard to do anything about that too from the outside The slave cylinder is bolted to the front of the tranny, just remove the two bolts and disconnect the line and its out. Sounds more like the throw out bearing. Does it only make noise if the engine is running while you press the clutch? |
May 22, 2012 - 2:01 PM |
No, it does not matter if the engine is running or not, the sound comes when the clutch pedal is pressed.
So the slave cylinder is accessable from outside, very nice, this is not the case on my SAAB for example (Sometimes I wish we still would use wirebased clutches instead of hyudralic..) -------------------- Black Toyota Celica GT-Four ST205 1996 (My love..)
May 23, 2012 - 8:43 PM |
Enthusiast Joined Nov 24, '10 From Worth, IL Currently Offline Reputation: 5 (100%) |
Bad throw out bearing (release bearing) had same problem when I installed my new clutch got some cheap Chinese TOB lasted 3weeks. Started to make noise, drove for about 1year, finally got pissed. Pulled off trans scrapped TOB and replaced with USA made TIMKEN or you can use JAPAN made SKF.
Had noise when clutch pushed in with engine running, with engine off it wouldnt make noise at all= BAD TOB. Besides that didnt have any other noises. |
May 23, 2012 - 8:57 PM |
My clutch was squeaking a while back. I would have sworn it was under the hood as well. Turns out all it was was just a loose nut that holds the clutch pedal/master cylinder together. It's worth checking.
Lo-Fi Version | Time is now: January 10th, 2025 - 8:30 AM |
