> oil type
post May 21, 2012 - 9:12 PM
xxgetbackupxx
Joined Feb 20, '12
From Florida
I have 221xxx miles on my car I use synthetic oil. I burn through oil to say the least. Example I changed my oil yesterday and drained out less than 2 quarts. Should I just go back to Dino oil? I only had 100 miles off till I hit 3000 between changes plus I added 1 quart. Maybe the synthetic Burns faster?I live in FL
So its hot out...maybe thicker oil? Anyone experience major oil burn? What oil works best 7afe?
post May 21, 2012 - 10:30 PM
5W-30.
post May 21, 2012 - 11:12 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
Yeah, suggest a really thin oil when he's burning oil...
Use a 10w30 or 10w40. You're in a climate that is always above freezing. Our cars take a higher viscosity oil and over the years, especially with your case, since you're burning, you need to raise the oil thickness. In the summer with that many miles, I would be running a 10w40.
post May 22, 2012 - 12:02 AM
Box
Joined Feb 23, '12
From Warrior, AL
20w50 is what I use. Being you're in the south as well, you'll be fine.
2001 Miata LS 5-speed
post May 22, 2012 - 1:21 AM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (RabidTRD @ May 22, 2012 - 2:12 PM) *
i'd go with this.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post May 22, 2012 - 4:20 AM
xxgetbackupxx
Joined Feb 20, '12
From Florida
QUOTE (Box @ May 22, 2012 - 1:02 AM) *
20w 50w is a bit extreme? Especially on start UPS, wouldn't that do more damage than good?
post May 22, 2012 - 8:42 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (xxgetbackupxx @ May 22, 2012 - 4:20 AM) *
Not when the temperature isnt going to drop below 70°, 20W-50 or 10W-40 is what Toyota recommends for this temperature range
post May 22, 2012 - 11:47 AM
Box
Joined Feb 23, '12
From Warrior, AL
20w50 is what was used and, was recommended to keep using, by the ASE Toyota master technician that owned it before me.
post Jun 14, 2012 - 12:45 PM
CELICA735
Joined Aug 5, '10
From WOODHAVEN NY
I two have the same issue with burning oil can I still use 20-50 up North in the summer months?
post Jun 14, 2012 - 3:34 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
I always go with semi-synthetic because our cars are older. But ill go with either 10/30 or 10/40 if I were you.
post Jun 14, 2012 - 4:01 PM
CELICA735
Joined Aug 5, '10
From WOODHAVEN NY
Thanks I have been using 10-40 but the one for high milleage my car has somewhere along the lines of 300,000 miles on it.
post Jun 14, 2012 - 6:07 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
All high mileage oils are semi synthetic. They have additives (synthetic) that add to engine life and extend the life of gaskets and seals.
post Jun 14, 2012 - 9:35 PM
RobbMeeX
Joined Dec 30, '11
From Atlanta via Mobile
Auto-Rx. I had low compression in my middle cylinders. Evened it right out. Supposed to free the rings.
QUOTE (Araykhel @ Oct 10, 2011 - 6:32 PM) *
Today I learned that I need a turbo to complete me.
post Jun 15, 2012 - 7:49 PM
6G96GT
Joined Jan 20, '08
From East Coast
Synthetic shouldn't burn faster. It is much more resilient to burning unless its blowing pass the rings pretty bad.
post Jun 17, 2012 - 9:45 AM
xxgetbackupxx
Joined Feb 20, '12
From Florida
In wondering if I jump back to semi synthetic, will it help stop burning past the piston rings as bad?
post Jun 18, 2012 - 10:11 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
QUOTE (xxgetbackupxx @ Jun 17, 2012 - 10:45 AM) *
It should
post Jun 19, 2012 - 5:47 PM
xxgetbackupxx
Joined Feb 20, '12
From Florida
Anyone have experince in this?
post Jun 19, 2012 - 5:56 PM
6G96GT
Joined Jan 20, '08
From East Coast
I don't really think synthetic will help stop the oil passing the rings. I had that problem before I had my engine rebuilt and tried everything. I concluded that I just wasted money on more costly synthetic oil and instead tried Lucas oil additive which does offer a guarantee to stop oil leaks and whatnot. I think that helped because I remember having to add less oil here and there. Bottom line though man, just get regular high mileage oil and keep on it by adding oil when needed. Don't waste your money on synthetic now. If you can, just get it rebuilt or swap it for another engine.
Lo-Fi Version Time is now: November 23rd, 2024 - 12:25 AM
