Stage IV (final stage for my SS-Four), Update: July 24th. |
May 23, 2012 - 10:42 AM |
Enthusiast Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
One year after "Great SS-Four rebuild" (http://www.6gc.net/forums/index.php?showtopic=78088) was finished I left my car in my mechanic's hands again to start fourth and final stage of my car's build. Goal has two parts:
a) check everything on the car after 12 months b) just slightly push car higher in terms of power (+20%) When I have my car back I plan just add some "unnecessary weight" and DONE! All finished. It has begun! What I can share now with is just the most important - new parts ready to install Bigger injectors... Bigger - custom build/modified - turbine (enlarged housing, enlarged wastegate, polishing, etc...) stay tuned... This post has been edited by malpaso: Jul 24, 2012 - 3:08 AM -------------------- No more replicas... This is evolution... This is SS-four :)
________[Featured Celica of 6gc.net @ 2010]_________ |
May 23, 2012 - 11:06 AM |
Cant want to see this one all done
-------------------- 95 gt coupe, v6 swap weekend toy
May 23, 2012 - 2:33 PM |
ooh this is gonna be good..
May 23, 2012 - 3:31 PM |
I can't wait for the dyno results
May 24, 2012 - 4:05 AM |
Cant want to see this one all done Me to . This must end one day ooh this is gonna be good.. Thanks mate! I can't wait for the dyno results In fact this is not much hunt for more (or even max) power. As I said expected gain is like 20% (so get to rounded 400HP what is not much for setup I have). For me this is more about gaining durability of engine and eliminate any possible risk of failure. For example what made me shocked is fact that turbine had plastic bearings???!!! PLASTIC! Can you believe this is an standard for turbine capable up to 500HP??? That engine must keep working under all circumstances and be reliable for my favorite long trips. Anyway. This time will dyno happen without my presence so no pictures or videos as last time . -------------------- No more replicas... This is evolution... This is SS-four :)
May 24, 2012 - 7:04 AM |
Good luck!
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
May 24, 2012 - 8:11 AM |
I'm awaiting the results with great eager. So tell me, since the rebuild, how does second gear going up-hill feel, Martin?
This post has been edited by SwissFerdi: May 24, 2012 - 8:11 AM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
May 24, 2012 - 8:49 AM |
interesting.. it must be made of some sort of thermoplastic capable of holding its shape at high temperatures.. although it probably only gets as hot as the oil flowing through it. maybe they went with plastic because it's lighter? therefore, quicker spool up?
May 24, 2012 - 1:12 PM |
Good luck! Thank you! I will keep you all posted. I'm awaiting the results with great eager. So tell me, since the rebuild, how does second gear going up-hill feel, Martin? You bet I will. My plan is to test it on San Gottardo on the way back home interesting.. it must be made of some sort of thermoplastic capable of holding its shape at high temperatures.. although it probably only gets as hot as the oil flowing through it. maybe they went with plastic because it's lighter? therefore, quicker spool up? Really do not know mate... but since I saw this video I'm glad they are away . http://www.youtube.com/watch?v=DcmWcqXCvrg -------------------- No more replicas... This is evolution... This is SS-four :)
May 30, 2012 - 9:42 PM |
Update: May 30.
Damn it was so close... And here it is fine as well (I'm so glad having those slim fans already installed) -------------------- No more replicas... This is evolution... This is SS-four :)
May 30, 2012 - 9:55 PM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
holy crap
May 30, 2012 - 10:01 PM |
Would you like some motor to go with that turbo
Oh wait i see it its that little thing bolted on behind the turbo lol -------------------- 95 gt coupe, v6 swap weekend toy
May 31, 2012 - 7:49 PM |
it looks like a knock-off gt2876r, would be interested to know what the spoolup is like on that, i have the gt2860rs i get spoolup starting at 2200rpm with over 1bar available from 2800rpm.
Everything i've heard about the 2871 and 2876 is that for the extra 20 - 40 HP over the 2860, they dont spool up any usable boost until 4000rpm! Also, i had a major problem with overboosting, the wastegate on the T28 housing is far too small for a 3sgte, so i had the internal gate hole ported out to 1mm less than the flap itself. and then what happened? even with the adjustable actuator arm tightened up i lost alot of response, my disco potato was no longer a spool monster!! -- anyhow, i had the hole filled up completely and had the path inside the turbine housing smoothed out and went to a massive 44mm tial external gate, now, finally, it works how i want it. have my cake and eat it, spool monster AND controllable boost!! yay i suppose in this case it doesnt matter if it overboosts, with those 800cc injectors you're probably running 1.4bar as your low setting hahaha -------------------- Mike W
Jun 1, 2012 - 3:59 AM |
To delusionz: In fact I can dive you one picture to compare GT2860RS and my new piece .
Since it is really custom build one I can only guess what result will be (in terms of spool rpm and range). So let's be surprised lately . Anyway overboost was one of many reasons for custom work. To kurt95gt: you have absolutely no idea how scared I was it will not fit... To enderswift: lol... my reaction was the same when I saw the picture (cuz because of circumstances I have not seen the turbine my self yet) This post has been edited by malpaso: Jun 1, 2012 - 4:01 AM -------------------- No more replicas... This is evolution... This is SS-four :)
Jun 1, 2012 - 6:55 PM |
Makes the disco potato look pathetic, keen to hear the results. I may have to get myself a 2876 compressor and housing
This post has been edited by delusionz: Jun 1, 2012 - 6:56 PM -------------------- Mike W
Jun 13, 2012 - 3:43 AM |
Update: June 13.
Nothing much to share now... just as works continues more and more things are too small, too short and nothing fits... ...so there is always something like proper size of hose missing in garage or some other tweaks are needed. That is why I can focus on small - not that much power related - tweaks . Like spacers: Sparco racing harness: Or some fancy dress for turbine : -------------------- No more replicas... This is evolution... This is SS-four :)
Jun 13, 2012 - 9:41 AM |
Martin, you keep on surprising with good things - I've never seen a turbo cover like that. Pretty cool. Those look like...35 or 40mm spacers?
'93 MX-5 LE |
Jun 13, 2012 - 9:49 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Wont that large of a turbo = massive lag?
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Jun 14, 2012 - 1:53 AM |
Wont that large of a turbo = massive lag? It's a GT28R based turbo, T28 is alot smaller than CT26/CT20b turbos. The compressor on this is a 2876 (or equiv) which is pretty much the same compressor on the larger GT30R (3076). this means a power output AND spoolup somewhere in the middle. the GT28R is known to spool well before 3000rpm and the GT30R is known to spool before 4000. So yes, the boost threshhold under 4000rpm will be lower than what you're used to with a GT28R and even the CT20b, _BUT_, the ball bearng centre cartridge means that the turbo will boost to its full boost threshhold as soon as your foot goes down, theres no response lag and theres no spoolup delay like the time it can take a journal bearing turbo to change from 40,000rpm to 140,000rpm for example is responsible for probably about 500 engine rpm of lag -------------------- Mike W
Jun 14, 2012 - 1:59 AM |
put simply, 2 GT4's, one with stock CT20b the other with this GT2876R , if you both dropped down and had a rolling start race from 3500rpm, the GT2876R equipped car will chew up and spit out the CT20b powered car right from the very first moment the accelerator pedal sinks.
a race from 2500rpm they would still start even, then boost kicks in and the GT2876R powered car will make 2 or 3 car lengths the moment 4000rpm comes around -------------------- Mike W
Lo-Fi Version | Time is now: November 23rd, 2024 - 8:34 AM |
