> 95 celica ST 7afe engine swap to Beams 3sge
post May 24, 2012 - 9:40 PM
foshojerry
Joined May 24, '12
From united states, ca
Hello, i am planning to do a small project engine swap on my 95 Celica ST from the US. I see lots of Forums that indicated on a 3SGTE swap into the 6 gen ST, yet i have many doubts on the technicality of the swap due to several problems: replacing transmission, engine mounts replacement, shift cable, smog emission regulation, maintenance!, etc. I then look at other engine option swap like Silvertop 4age 20 valve engine but it is only 160hp. What i want relatively out of this engine swap project is to have "minimal" problems and yet "reliable/powerful". I was looking at the 200hp Beams 3SGE economical natural aspirated engine and sure looks tempting. Several questions: i see many forums on swapping the Beams into their "GT" model which has all the right mounting and assembly in compatibility for the swap. I know on the ST, the engine mounts are totally different. Has anyone done this kind of swap in their ST? Will a fully healthy Beams engine ship from Japan pass US smog regulations? If so, what are the crucial points i need to watch out for and what parts do i need to replace? I am also turning the automatic into a manual as well. (If i am going to go into this project, "i will be getting a full front clip with manual transmission imported here"). If i get the full front clip i have all the parts and mounts for the picking! Well any body out there that can help me out on this topic i am greatly appreciative! I LOVE MY CELICA and kept it in awesome conditon, i will post some pictures up when i get a chance.
post May 24, 2012 - 9:48 PM
enderswift
Joined Jul 12, '08
In my opinion the beams swap is no less technically involved than a gte swap. They are both s-series block and you will therefore run into the same problem with the mounts.Furthermore an st celica would need a new transmission no matter which engine you go with.
Beams engines were never sold in the states and do not have obd II wired in. This means that it wont pass smog. The most common way around this is to swap a pre '95 celica, since those don't need to be emissions tested.
post May 24, 2012 - 9:52 PM
foshojerry
Joined May 24, '12
QUOTE (enderswift @ May 24, 2012 - 10:48 PM) *
post May 24, 2012 - 9:58 PM
foshojerry
Joined May 24, '12
sorry new user, learning how to reply, i see..the obd 2 situation, the transmission, enderswift what do you mean by the "pre-95s" you mean the 94, if so, why doesn't the pre-95s need to be emission tested?
post May 24, 2012 - 10:03 PM
enderswift
Joined Jul 12, '08
1996 was the year all manufacturers were required to switch to obd II, which is just a computer system for monitoring emissions. Any car that was built without obd II is exempt from emissions testing because all of the testing facilities don't have the obd I equipment anymore. So if you're really concerned about emissions you need to buy a 94 or a 95 and swap a motor into that.
I just saw you have a '95 haha. You're fine to swap whatever you want. I would look up the beams threads that richee3, njccmd2002, and richochet1409 made; they did a good job documenting what's involved so your best bet is to start there
This post has been edited by enderswift: May 24, 2012 - 10:12 PM
post May 24, 2012 - 10:10 PM
foshojerry
Joined May 24, '12
i see thank you for that info, hmm i do though have a 95, any suggestions on which transmission that can swap along? notice though i will buy a full front clip manual transmission included, why must i not use that? sorry just a day fresh looking into this swap info.
post May 24, 2012 - 10:15 PM
foshojerry
Joined May 24, '12
thank you again, makes more sense
post May 24, 2012 - 10:17 PM
enderswift
Joined Jul 12, '08
If you buy a clip then you can use its transmission no problem
post May 24, 2012 - 10:20 PM
mkernz22
Joined May 10, '10
From MA
Welcome to the forum, first off. Secondly, definitely search for some of the 3sge swap threads, there are a few. The transmission that comes with it is perfectly suitable for the car. You will only need 3 of the 4 engine mounts because the drivers side one is the same between GT and ST. You will need to get GT engine mounts for the passenger side, and the front and rear mounts as well as the GT cross member.
post May 24, 2012 - 10:34 PM
foshojerry
Joined May 24, '12
niiice, things are looking good so far, sure will look into those threads, this is awesome, i say U.S. 1000$ to hire a mechanic to do this swap, please comment, and thank you mkrenz22
This post has been edited by foshojerry: May 24, 2012 - 10:36 PM
post May 24, 2012 - 10:41 PM
mkernz22
Joined May 10, '10
From MA
It's probably going to be a lot more than $1000 for the job if you have a mechanic do it.
post May 24, 2012 - 10:46 PM
foshojerry
Joined May 24, '12
guesstimated price?
post May 24, 2012 - 10:48 PM
mkernz22
Joined May 10, '10
From MA
I couldn't tell you. Most places won't do swaps like this anyway.
post May 24, 2012 - 10:53 PM
foshojerry
Joined May 24, '12
is it because of legal and technical issues? hmmm, ask a friend to borrow a crane and tools and maybe maybe i will convince someone to help me out...whoomp whoomp...
post May 24, 2012 - 10:56 PM
mkernz22
Joined May 10, '10
From MA
I'm honestly not sure, they usually only swap the same engine if one is bad. It's really not that hard of a process if you read up on how to do it
post May 25, 2012 - 12:11 AM
ricochet1490
Joined May 3, '11
From Ohio
my beams clip i'm pretty sure has OBD2... just saying...
post May 25, 2012 - 12:17 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
first off OP, why dont you get more specific on your location rather than USA. If you are in California you will NEVER get a BEAMS to pass smog. that engine was never offered in a car in the USA so it will never pass. and like mentioned a BEAMS will be no different technically than a 3S-GTE and it will be much harder to find parts for it. If you really want to do a good reliable swap that makes more than 200HP, look into a V6 swap. Either a 1MZ or 3MZ. there are more and more of these being done now.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 25, 2012 - 12:21 AM
ricochet1490
Joined May 3, '11
From Ohio
Bonzai lives in CA, how did he and the original owner of the car get it to pass smog?
Edit: I don't mean to thread jack, but it's a relevant question I think
This post has been edited by ricochet1490: May 25, 2012 - 12:22 AM
post May 25, 2012 - 12:31 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Do none obd2 cars neex to pass smog in cali?
an if they do isnt like a one time thing when you first buy the car?
94 st hatch my daily driver
n
post May 25, 2012 - 12:47 AM
foshojerry
Joined May 24, '12
good points whoomp whoomp, can't pass smog spec and hard to find parts, hmmmm please need to know what sets of parts to be more specific are they "hard to find" for example maintenance parts like belt replacements, bearings.... Everything else seems universal to change for maintenance and definitely correct me if this isn't so. Yet the smog i have to question this: Since i know that the beams engine has the obd2 and does not pass smog in US regulation (correct me if i am wrong), and does the 95 year really matter are all in the mix. Good point with the v6 yet i heard not say it is that: you can't do an engine swap that is no greater in # of cylinders from its original state of model make can't swap a 6 when original is a 4 (regulations again). i live in Los Angeles California
This post has been edited by foshojerry: May 25, 2012 - 12:55 AM
Lo-Fi Version Time is now: February 21st, 2025 - 2:16 PM
