Fuse Problem ?, Help |
Jan 22, 2003 - 8:57 AM |
Enthusiast Joined Dec 27, '02 From Sleep in Warren chill in clinton twp, works/school in detroit Currently Offline Reputation: 1 (100%) |
Well dis mornin I started my car and found out that my clock and radio doesn't work anymore WTF....
I mean all of my electronic stuff works tho -------------------- |
Jan 22, 2003 - 9:59 AM |
Enthusiast Joined Oct 24, '02 From pennsylvania Currently Offline Reputation: 0 (0%) |
check the fuse box next to the steering wheel. it's the same fuse that controle the radio and the clock. there should be a diagram on the back of the plastic cover that will tell you which on it is. jhope that helps
Jan 22, 2003 - 1:15 PM |
oh also my friggin auto start is also acting up....
probably all of this is cause by my auto start Fuq why does it have to be 8 degrees out there -------------------- |
Jan 22, 2003 - 9:48 PM |
Enthusiast Joined Nov 12, '02 From Columbus, Ohio Currently Offline Reputation: 15 (100%) |
Check the fuse in the car, there is also a fuse in the engine bay fuse box. It's blue 15 amp buss fuse. IT's labeled.
Jan 22, 2003 - 10:06 PM |
Here's the deal
my clock seem to not to work anymore and I can't find the clock fuse and my cd player seems to have power but won't turn on .... i mean I can eject my cd out although I still can't turn my cd player on oh does anybody know what's the wiring code for out clock and radio -------------------- |
Jan 23, 2003 - 11:35 PM |
Enthusiast Joined Jan 15, '03 From Waipahu, Hawaii Currently Offline Reputation: 0 (0%) |
i thought all you have to do is plug a 15 amp fuse or what not into where it says clock and radio in the back of the panel to where the fuse box is. |
Jan 24, 2003 - 12:01 AM |
Enthusiast Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
I believe that the clock and the radio fuse are diff, on my gt, the clock fuse is a 10 in the case next to the airbox.
Also if your cd player is aftermarket it should have a fuse in the back of the unit itself. But you car is a wee bit diff than mine, good luck -------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Jan 24, 2003 - 8:46 AM |
see my radio fuse is 20 amp(yellow) i changed it already but my cd still doesn't work
neither is my clock wtf really need help here so I'll have an idea what to do this weekend.....(hopefully its at least 30 degrees tho trying to work in 3 degrees kinda sux) -------------------- |
Lo-Fi Version | Time is now: November 24th, 2024 - 5:58 PM |
