> 1zz troubles
post May 30, 2012 - 11:45 PM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
a friend of mine is having problems with his '99 corolla.... he says its missing at idle and severely lacks power when dropped into gear; its a 1zz.. if any other info would be helpful just ask and i'll see what i can get from him. Thanks in advance.
This post has been edited by d3ath2009: May 31, 2012 - 2:09 PM
post May 31, 2012 - 12:10 AM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
Performed a compression or leak down test yet?
Car throwing any cel's?
Cleaning and improving my new found yoter little by little.
post May 31, 2012 - 7:41 AM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
Don't have the equipment to do compression test and I can run the code checker on it when I get home this weekend... I'll update when I find anything.
post May 31, 2012 - 12:12 PM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
ok, so compression is 100 on 2,3,and 4 and 80 on 1.. he also said that the CEL flashes constantly
post May 31, 2012 - 12:13 PM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
QUOTE (d3ath2009 @ May 31, 2012 - 7:41 AM) *
You can rent one from autozone for $35-45 and when you're done take it back and get your refund. A leak down test would yield better results as it checks alot more areas, but most don't know how to do one or what it is.
If the compression and cel's comeback ok then i would start with the most common and easy fixes such as timing, vacuum leaks etc.
This post has been edited by Takumi-FujiWaraST: May 31, 2012 - 12:16 PM
post May 31, 2012 - 12:44 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
was that test done at temp or was it cold? thats pretty low...
post May 31, 2012 - 1:05 PM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
Those are terrible numbers and the cylinders have more than a 20% variation which at the most cylinders should on vary 10-15% between each cylinder.
Was the test cold and at WOT?
If not let it cool down then re test it dry. Then re test it wet (pour an oil cap full of oil down in each cylinder if it bumps the numbers up a good bit it's his ring's if not look into valve issues or a blown head gasket) the oil temporarily seals bad rings.
This post has been edited by Takumi-FujiWaraST: May 31, 2012 - 1:07 PM
post May 31, 2012 - 1:59 PM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
i need to get this moved.. found out its a '99, hence a 1zz instead of a 7a like i thought
post May 31, 2012 - 5:27 PM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
Reguardless you still need to do a cold WOT test then compare those numbers to the WET test, it's lossing compresson somewhere and the variations between the cylinders is a bit much.
Post results when you get those new numbers.
post May 31, 2012 - 5:39 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
you are supposed to do compression testing with the engine fully warmed up. and yes those numbers are very very bad. doubtful its the head gasket because they dont go bad on the ZZ engines (usually) but it could be a broken VVT gear, bent valves, timing way off. there is just way too many possibilities. I havent heard much on the corolla side but in the celica world with 2000-2003 1ZZ-Fe engines, they drank oil due to having bad piston rings. its possible this is the same situation.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jun 2, 2012 - 12:40 PM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
update: new plugs and plug wires.. now it does fine at revs, just not so much at idle, especially when its dropped into gear.. at idle, in gear it shakes horribly... can also hear what sounds like loose timing chain.. ideas?
post Jun 6, 2012 - 4:25 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
there are no plug wires on the 1ZZ, its a coil on plug
post Jun 7, 2012 - 10:45 AM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
QUOTE (Smaay @ Jun 6, 2012 - 4:25 PM) *
there are definitely plug wires, how else would the spark plug be getting spark? (maybe slight confusion, by plug wires i mean the ones that go from the coil/distributor/whatever it happens to be to the valve cover and down to the plugs)
post Jun 7, 2012 - 11:02 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
There are no spark plug wires on a 1ZZ.
None of these guys.
Spark plugs on the 1ZZ plug into these:
Which plug into the harness.
This post has been edited by 95CelicaST: Jun 7, 2012 - 11:04 AM
**** Photobucket
post Jun 7, 2012 - 1:03 PM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
Yes there are wires on a 1zz(1998-2000) thats the second gen 1zz(2000+) that has COP (Im surprised smaay didnt now that... Oh wait no I'm not... rolleyes.gif )
P.s. The plug wires you posted are the exact type that go in the corolla laugh.gif
Plugs
Plugs
Plugs
Plugs
Shall I go on or is that enough???
This post has been edited by hatchy_gt-s: Jun 7, 2012 - 1:20 PM
post Jun 7, 2012 - 1:07 PM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
QUOTE (d3ath2009 @ Jun 2, 2012 - 1:40 PM) *
Honestly if you dont know what you're doing then just take it 2 a shop. It's nearly impossible to diag a car over the internet w/o having all the right info. If you really want help I can give you a list of what info would be needed and MAYBE we can help.
This post has been edited by hatchy_gt-s: Jun 7, 2012 - 1:13 PM
post Jun 11, 2012 - 11:49 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
99 corollas came with a (2nd gen) 1ZZ so i wasn't sure. but your compression is still way too low. BTW your 1ZZ did not have VVT. there are just too many variable without seeing the car
post Jun 13, 2012 - 8:04 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
rings stuck on cyl 1, wet compression test will show this. number is too high for a burnt valve. time to rebuild.
Lo-Fi Version Time is now: February 18th, 2025 - 2:17 PM
