![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) ![]() |
![]() Enthusiast ![]() Joined May 29, '12 From NC Currently Offline Reputation: 0 (0%) ![]() |
![]() Appreciate it. Forgot to mention this little car made it into a calendar fot january using one of my snow pictures. I should have a pretty wicked valve cover here soon for the "new" engine aswell. -------------------- ![]() Cleaning and improving my new found yoter little by little. |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) ![]() |
Good stuff, looks like you are enjoying your application!
I enjoy the chassis alot, i'll enjoy it more if the new engine doesn't sound like the last with it's indian rain dance going on in the block.
Kinda limited on days i can put the engine in, but soon enough. -------------------- ![]() Cleaning and improving my new found yoter little by little. |
As promised........
![]() ![]() ![]() ![]() ![]() This post has been edited by Takumi-FujiWaraST: Apr 2, 2013 - 10:36 AM -------------------- ![]() Cleaning and improving my new found yoter little by little. |
Insert lonely island jizz in my pants video here
I Appreciate it, wish i had money to paint my bay like orignally planed but ohwell.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) ![]() |
that's pretty frickin' cool.
-------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Thanks hopefuly it will run half as good as it will look.
That is damn nice...
If my valve cover wasn't going to be hidden by a IC, i'd offer you money to paint mine! |
I wish I had your painting skills.
![]() ![]() -------------------- 2001 Miata LS 5-speed
I can not take credit for anything but the idea, i wanted something rough/tough to match the car, lets be honest for what i use it for it would do no good being a "pretty" car as that would last a week tops.
This was actually my second idea first was a urban camo, but due to the ribs on the top it was hard to get a hard line. I'm around alot of people i shine at body work and mechanical, the only air brushing i've done was back in college when i was taking a 1yr program for autobody. At the moment i'm looking for a better job as the last guy i worked for did me and alot up here dirty and left over night, big mess. Anyway if i can get one soon expect a sprayed 7A. Dale calhoun did the VC. -------------------- ![]() Cleaning and improving my new found yoter little by little. |
![]() ![]() ![]() ![]() ![]() -------------------- ![]() Cleaning and improving my new found yoter little by little. |
Got the engine in this past sunday worked on it from 4:30'ish to 8 ran out of light.
sunday ![]() Most recent. ![]() ![]() ![]() I know i need to pressure wash the bay but needs to run first.Also deleted the factory tb spacer deal and ported the tb awhile back. -------------------- ![]() Cleaning and improving my new found yoter little by little. |
Cars been up and running for awhile now. Gobbs more power (For what is is), still goes anywhere ground clearance permitting.
![]() ![]() ![]() ![]() http://www.youtube.com/watch?v=5cpec22Tvdg -------------------- ![]() Cleaning and improving my new found yoter little by little. |
Whats the minimal compression numbers on the 7a's? just need the minimal numbers nothing else at this time, i figure 140psi would be close to minimum factory specs due to the CR for the engine.
Read that 142psi is minimum so time to start diagnosing this engine tomorrow. Hope its valve stem seal issues. This post has been edited by Takumi-FujiWaraST: May 14, 2013 - 5:48 PM -------------------- ![]() Cleaning and improving my new found yoter little by little. |
![]() Enthusiast ![]() Joined Sep 25, '11 From GreatSmokyMtns NC Currently Offline Reputation: 3 (100%) ![]() |
Selling it?
Compression Pressure:
1.8L (7A-FE) ....................................... 191 psi (13.4 kg/cm) Minimum Compression Pressure ........... 142 psi (10.0 kg/cm) Maximum Variation Between Cylinders .. 14 psi (1.0 kg/cm) -------------------- 2001 Miata LS 5-speed
Selling it? Yeah maybe, got to figure out oil smoke issue now. Oils straight up pouring out of two exhaust ports after a 5sec start up starts dripping out of #1 like water. You see it on CL? Compression Pressure: 1.8L (7A-FE) ....................................... 191 psi (13.4 kg/cm) Minimum Compression Pressure ........... 142 psi (10.0 kg/cm) Maximum Variation Between Cylinders .. 14 psi (1.0 kg/cm) Found that, i'll use precentage instead though for variance always have. Appreciate it though. -------------------- ![]() Cleaning and improving my new found yoter little by little. |
I was looking at parts and how could you miss that airbrush work.
Lo-Fi Version | Time is now: April 23rd, 2025 - 11:05 AM |
