10 Pages V  « < 8 9 10
> Takumi's 94 Toyota Celica ST
post Oct 4, 2013 - 10:42 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
QUOTE (Box @ Oct 3, 2013 - 10:53 PM) *
I did stop
An I replaced the cable lol
94 st hatch my daily driver
n
post Oct 5, 2013 - 9:28 AM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
Well at the moment the 100amp is not hooked up if i try and jump it i get sparks, but other large amp fuse is good so it starts without a problem each and everytime. Now i did notice the wire from battery and nut on the bottom of starter will move like the stud inside is lose as i can only tighten it so much before it starts turning on itself.
Cleaning and improving my new found yoter little by little.
post Oct 5, 2013 - 9:44 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
QUOTE (Takumi-FujiWaraST @ Oct 5, 2013 - 10:28 AM) *
That might be your problem
Its getting a bad connection from the sound of it
n
post Oct 5, 2013 - 11:31 AM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
Yeah well going to try everything i know to do love driving the little car its fun even with 80whp. Thanks for ya'lls suggestions, if i can't track it down i'll be hollering back.
post Oct 5, 2013 - 6:41 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Good luck!
n
post Oct 11, 2013 - 6:28 PM
kevin311
Joined Dec 23, '12
From North Carolina
Good luck man. Whereabouts in NC are you?
post Oct 11, 2013 - 7:44 PM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
Got it going and was the alternator power wire, thanks fellas.
Kevin im in boone nc.
post Oct 14, 2013 - 6:42 PM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
Car hits a brick wall at 4k sounds as if the intake is opening way to much, so good bet my cam timings off aye?
post Oct 14, 2013 - 7:11 PM
Box
Joined Feb 23, '12
From Warrior, AL
I'd check cam timing and then ignition timing.
2001 Miata LS 5-speed
post Oct 14, 2013 - 7:16 PM
kevin311
Joined Dec 23, '12
From North Carolina
That's cool, explains the want for snow tires, def need them up there. I live in a small town, Stem. About an hour North of Raleigh (out in the country). Glad you got you alt issue fixed. Sounds like now a timing issue?!
post Oct 14, 2013 - 7:17 PM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
Ignition has been adjusted both ways with light still a wall, tons of intake noise under wot so i'd say im off a tooth or so on the cam's.
post Oct 19, 2013 - 11:05 AM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
Anybody got an actual picture of the intake cam gear at tdc on the 7afe? im pretty sure my marks are correct but would like to make sure my cam timing is right.
Lo-Fi Version Time is now: April 23rd, 2025 - 4:59 AM
