> Drum to Disc
post Jun 2, 2012 - 12:38 PM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
Does anybody know if the rear disc brakes from a 5th gen can be used for a drum to disc conversion?
This post has been edited by d3ath2009: Jun 2, 2012 - 12:40 PM
post Jun 2, 2012 - 12:43 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Call a parts store An check part numbers
94 st hatch my daily driver
n
post Jun 2, 2012 - 2:04 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Yes... it's been done and documented... http://www.6gc.net/forums/index.php?showtopic=45705
This post has been edited by Kwanza26: Jun 2, 2012 - 2:05 PM
post Jun 3, 2012 - 6:05 PM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
awesome, great to know.. thanks guys
post Jun 4, 2012 - 3:09 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Key issue is the centrebore. Fifth-gen hubs use a 54 mm centrebore, while sixth-gen hubs use a 55 mm centrebore.
Coomer later discovered that the rotors he thought fit actually did not, and actually cracked one. Thus the notice in that thread.
For 5SFE-powered Celicas:
Front rotors
90-91 255 mm diametre, 22 mm thick, 54 mm centrebore
92-93 277 mm, 25 mm, 54 mm
94-99 275 mm, 28 mm, 55 mm
Rear rotors
90-93 269 mm, 10 mm, 54 mm
94-95 269 mm, 10 mm, 55 mm
95-99 269 mm, 9 mm, 55 mm
So, calipers, brackets, backing plate and e-brake cables from the fifth-gen and an early sixth-gen rotor.
This post has been edited by Galcobar: Jun 4, 2012 - 3:13 AM
post Jun 4, 2012 - 7:31 AM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
thanks for the warning.. so i need everything from the 5th gen except rotors.. again, thanks to everybody
Lo-Fi Version Time is now: November 22nd, 2024 - 7:54 PM
